Old 01-28-2005, 10:55 AM
dsoby's Avatar
dsoby dsoby is offline
Boat: 2002 X7, LTR
Starter Removal
Has anyone removed the starter on an LTR engine. I need to grease the spline but don't know exactly how to take the starter off.
Old 01-28-2005, 11:24 AM
Thrall's Avatar
Thrall Thrall is offline
Boat: '06 X2 MCX
Assuming the starter is accessible.
First, disconnect the battery.
Disconnect the wires from the solenoid. 2 posts w/ wires I believe.
Remove 2 bolts on bottom of starter that connect it to the engine block.
Pull the starter motor out.
If there are any shims between the starter and block, be sure to reinstall them. (There probably aren't any.)
Old 01-28-2005, 11:41 AM
No need to actually pull the starter, it'll try to fall out by itself. Loosen the two bolts until they're almost out. Then remove one bolt so you can get into position to hold the starter up while you remove the last bolt. Put something under the starter in case it falls, so you don't damage anything. These are fairly heavy.
Thrall- how are things in Pahonix?
