Go Back   TeamTalk > General MasterCraft Topics > Find A Pull / Give a Pull
Old 04-26-2007, 01:24 PM
ironj32's Avatar
ironj32 ironj32 is offline
Boat: 2013 SAN G23, XS550
ballast question
so all the ballast info that i am seeing is for the systems the have intake/outake of water through the same thru hull hole. on my 2000 xstar i have the intakes in the transome and the outakes goe up through the hull right next to the vent holes. is there some type of valve that is used for this? reason i am asking is i am going to add a fourth pump and put my bow sac on an auto switch.
Smokey, this is not 'Nam. This is bowling. There are rules.
Old 04-26-2007, 02:16 PM
P-hat_in_Cincy's Avatar
P-hat_in_Cincy P-hat_in_Cincy is offline
Boat: MasterCraft Prostar 205V "wakeboard edition", 2004
Yes...swing check valves (c/v) are used if it's a reversible pump system.
If it's an aerator system, there are 2 pumps...1 fill and 1 empty...no directional c/v required other than to stop back flow out the inlet.
2004 MasterCraft Prostar 205v 'Wakeboard Edition'
Old 04-27-2007, 08:15 AM
ironj32's Avatar
yeah it's a reversible pump system. right now the three pumps are all on their own thru hull. i'll probably end up putting the new pump on it's own thru hull as well. is there a certain location (distance from the pump & elevation in the boat) that will work best for the swing check valve?
Old 04-27-2007, 01:06 PM
ironj32's Avatar
i just realized this is in the find a pull/ give a pull forum...whoops! it's been a long week. time to bail out of work and hit the lake!
