Old 04-23-2007, 09:37 PM
beatle78 beatle78 is offline
Boat: 2001 Prostar 205V
Impeller puller for 205V / old X-star / old X2/ X1
Hi guys,
I've decided I really need an impeller puller for my 205V. I see different sizes for sale and I want to make sure I get the one for my size impeller that will fit in the tight spaces between the exaust silencer ect...
Thanks in advance!!!
beatle78
Old 04-24-2007, 12:43 PM
Harvey's Avatar
Harvey Harvey is offline
Boat: 2006 X1
2 Paint can openers, available at any home depot or lowes for free. Or if you want to spend money get a pair of bent needle nose pliers.
A lake carries you into recesses of feeling otherwise impenetrable. ~William Wordsworth
Funny, it's almost like ol' Wordsworth owned a Mastercraft!
Old 04-24-2007, 12:51 PM
ttu's Avatar
ttu ttu is offline
Boat: 2007 X2
it should be the one that fit's 1 9/16" to 2 9/16".
i used the paint can opener when i had the direct drive but with the limited amount of room i bought the impeller puller with the vdrive.
it worked real well.
db
Old 04-24-2007, 08:28 PM
thanks guys. I love the paint can opener idea, but I can barely get in there. I need something I can secure on there and take my time turning it out.....
Old 04-25-2007, 07:50 PM
mallees's Avatar
mallees mallees is offline
Boat: Matercraft X2 2004 350 MCX
I found it easier to remove the pump and replace the impeller on the bench. It only took 10 mins to pull the pump out. Total job takes about 25 mins, and you know its all good coz you can see what you are doing rather than relying on feel.
Old 04-26-2007, 09:41 AM
mallees,
so you actually removed the impeller housing from the block and did it that way?
Any problems along the way you could share?
thanks,
beatle78
Old 04-26-2007, 10:02 AM
erkoehler's Avatar
Two screwdrivers are the easiest and cheapest way to get them out.
www.lauderdalelakesmarina.com
Old 04-26-2007, 11:21 AM
Diesel's Avatar
Diesel Diesel is offline
Boat: 95 Prostar 205
Just unplug the coil and crank away. A few turns of the engine and the damn thing comes flying out.
05 ProStar 209, Navy Flake, Slate Gray, MCX 1:1
Old 04-26-2007, 12:45 PM
hmmm... I'll have to try the engine cranking method.....
Erk,
Have you tried this on a v-drive? It can get pretty tight in there. Any concern with prying the screwdrivers against the impeller housing?
thanks
Old 04-26-2007, 01:34 PM
Diesel's Avatar
Erk,
thanks
I used to work on an Xstar/X2 and if you lube it up a bit it will come right out every time.
