Disappointed in towing
I traded in my wife's 08 Tahoe 5.3 motor with 100k miles for a 12 gmc Yukon 5.3 l with 15k miles. I towed my 02 xstar yesterday for the first time yesterday. The tow includes a large climb over parleys summit. This gmc would not down shift the way my 08 Tahoe did. I was in tow/haul mode and had the gas pedal down all the way and the down shift took forever. I could do 65 or so up and over the summit in my 08 and I was struggling to be at 50 in the gmc due to the fact it didn't down shift to keep the speed consistent. What am I missing
Different rear end. When they went to the 6 speed they also put substantially higher gears in the rear ends for the sake of economy.
1997 Prostar 190, TBI 350, 1:1, OJ XMP 13 x 11.5, Stargazer, Hot Shower, Heated Drivers Seat, Reuben/Mountain Rock/Nite Navy |
Yep the solution is too find a 3.73 to go with the 6 speed like what was probably in your 08 with a 4 speed. I think the 6 speed uses a 3.08 or 3.23. Also, you can tow in 5th gear to help
1981 MasterCraft 19' Skier 351W PowerSlot Deluxe Long gone is the Trans AM
Your GMC is under warranty. Take it in and have it checked out. Even with a higher rear differential ratio the lower ratios of the first 4 sets of the 6 speed auto give you a better low end final drive ratio for towing. The sixth gear set is to give the extra miles per gallon rating on highway and all six allows for additional city MPG as under normal driving shifts come quicker reducing rpm. Results help raise the all important CAFE rating. At first glance your issue sounds like a programming issue or a speed sensor.
Something is going on. The 4 speed and 6 speed have similar ratios in the 3/4/5 gear range. Definitely have it looked at.
Is there an OD button and was it turned off?
You can drank em purty but ya caint drank em skinny... |
Some times you can look into a .. Super chips, or bully dog system.. to reprogram your truck and in tow modes change shift points
Something is wrong...
I towed my last boat from Florida to Michigan with a 5.3 Tahoe with a 6 spd, and through the mountain of Kentucky/Tennessee the trans was shifting into 4th to maintain 75 mph. |
tow/haul generally limits shifting, but that sounds extreme. The different rear end would explain more frequent downshifts, not what he describes.
Either your tranny is not programmed correctly, or perhaps that particular model has a real slow downshift mode in tow/haul. You can always manually drop it down, yes? |
#10
