Old 04-11-2007, 07:18 PM
Chief's Avatar
Chief Chief is offline
Boat: 2006 Maristar 200VRS
Extra Ballast For The Maristar
Just completed the addition of approx 400lbs of ballast to "betsy". Pretty simple and under $100 bucks. Will be optesting this weekend, Trick you in? Fly high bags found on ebay $30.00 a piece.
2006 Maristar 200VRS MCX
KGB Ballast and all the works!
Tow Veh: 2010 Toyota Tundra
Bike: 2007 HD Street Glide
Beer:Sam Adams Boston Lager/ Cherry Wheat, Petes
Strawberry Blonde, Petes Wicked Ale
Chief Petty Officer: "Results not excuses"
"You Can't Beat a Tree"
Old 04-11-2007, 07:19 PM
Chief's Avatar
One more picture.
Old 04-11-2007, 08:55 PM
canada air canada air is offline
Boat: 1995 maristar 200vrs, 275tbi
what kind of connectors are you using to connect to sacs.
i have older maristar 200vrs with a 350 on each side of engine, 550 in front walkway, 100 waterbed tube in locker and 150 in nose of lead. 1500total. very nice when you ad people to mix
Old 04-11-2007, 09:15 PM
Chief's Avatar
They are the Fly High Pro X connectors. I ordered them from Bartswatersports.com . The nipples on the bags accept the click type connectors. I hope it's going to enhance the 600lbs factory installed tanks. I also have a 350lb bag that I will have to manually fill above the KGB tank in the front if the wake gets to peaky. I will be experimenting with what works best.
I hope the bags will empty into the tanks and out the overboard discharges with little or no work when draining.
Old 04-12-2007, 07:50 AM
dpolen's Avatar
dpolen dpolen is offline
Boat: Med Blue 2012 X2, Illmor 5.7
Send a message via MSN to dpolen
Just curious, what are you using for your pumps? Are they built in to the boat? I just got my bags, but debating how I'm going to fill them up.
Old MC: 1998 Maristar 225 VRS
Rig: 2009 Chevy Tahoe LTZ
He who dies with the most toys wins...I'm losing right now!!!
Old 04-12-2007, 08:22 AM
Chief's Avatar
Using the factory installed pumps to fill the bags: basically the overflow from the tanks will be filling the bags and then when the bags are full the overflow will discharge thru the tank overflow thru hull fittings.
Old 04-12-2007, 08:35 AM
dpolen's Avatar
Thanks...I'm jealous, that seems like a nice easy way to do it....wanna trade?
Old 04-12-2007, 01:02 PM
Chief's Avatar
Only if you want the payment too!
Old 04-12-2007, 01:35 PM
Sodar's Avatar
Sodar Sodar is offline
Boat: '07 ProStar 197 w/ MCX
I know nothing about ballast.... How do you drain the bags when you are done?
Old 04-12-2007, 08:18 PM
Chief's Avatar
Flip the switch to drain. Quick tutorial, My Maristar 200VRS has three ballast tanks, one on each side of the engine and one where the ski locker would be for a total of 600lbs (they say). Each tank has a Jabsco water ballast puppy reversible pump that will fill and drain the tanks.
When the tanks are full they have a vent connection that will discharge water over the side to let you know the tanks are full. I connected that vent tube to the lower connection on the bags (which sit on top of rear tanks) so when tank is full it will start to fill bag. When the bag reaches max capacity the upper connection is now connected to where the tank vent was and the water will discharge to let you know the bag is full.
Now the uncharted water is when the pump starts draining the tank will it pull the water from the bag? I will be testing this weekend and will post results. I may have to install check valves on the vents so air does not get sucked back through the vents causing cavitation of the pumps.
To be continued.................. Hope this helps clear things up, but then I have had a few beers already!
