Old 01-19-2005, 10:56 PM
Brn85ss Brn85ss is offline
Raw water strainer location
Has anyone out there had trouble finding a location for your raw water strainer? The engine box on the stars &stripes tapers on the back side and leaves little room.I really wanted to put it up stream from the tranny cooler,since I found garbage in the cooler last summer.Any ideas would be helpful.
Thanks
Old 01-20-2005, 06:35 AM
Boat: 95 PS 190 EFI
on my '95 PS190, my RAW Water Intake comes straight up from the hull, into a 90deg fitting, into my strainer, then straight out of the strainer curving down to the transmission (I almost said tranny! ) cooler.
Got my kit from www.skidim.com. They even supplied the correct size barb fittings. You won't be sorry you did it. Just be sure to dain it when you winterize.
If one day you're asked:
Will you say:
It's time to SKI.
Old 01-20-2005, 10:33 AM
east tx skier's Avatar
Boat: 1998 Ski Nautique
As Jimmer mentions, the 90 degree hose barb is key in my opinion. I didn't use one and just barely had enough room without running into one of my engine mounts. It enables you to not have to bend the intake hose downward. Mine's upstream from my t-cooler, too.
A word of advice, always cut leaving a little more hose than you think you need. I came up short on the intake hose and had to drive to Dallas in lieu of ordering it and not skiing that day. (My nearest dealer is a CC dealer and they use 1" (not 1.25") intake hose).
As for cutting the hose, I figured I'd have to use a hacksaw, but discovered that there's not really enough room to get a good saw stroke going. If that turns out to be an issue, use a pocket knife (it's just rubber afterall) and trim the wire reinforcement with a pair of wire cutters.
Previous: 1993 Prostar 205
FAQ
Be kind. Have fun.
Old 01-20-2005, 02:20 PM
Thanks for the replies guys,however mine won't fit in the locations you describe because the engine box tapers in the back.by the way if you guys ever have to cut your hoses again pvc pipe cutters work great.also I already tried 1 90 degree fitting and 1 straight,not even close to working
Old 01-20-2005, 05:01 PM
MarkP's Avatar
MarkP MarkP is offline
Brn,
What strainer did you buy?? Just curious.
The wife calls me abrasive
Old 01-20-2005, 07:26 PM
Originally Posted by MarkP
Brn,
I bought the sherwood 1" with 90 degree assuming I would be able to make it fit.
Old 01-21-2005, 10:34 AM
I'm assuming the PCM engines of the day were using 1". I'm surprised that doesn't fit. Must be cramped in there.
FAQ
Be kind. Have fun.
Old 04-22-2006, 05:55 PM
jackpita jackpita is offline
Boat: 2008 X14. Sold Maristar 210, 1992, 351
Send a message via AIM to jackpita Send a message via Yahoo to jackpita
Did you find a place to put it?
My 92 Maristar has a tight fit as well.
thanks
