Old 03-08-2007, 09:16 PM
WAT8415's Avatar
WAT8415 WAT8415 is offline
Boat: 1991 Prostar 190
De Winterizing
I am getting my PS190 ready for the season. It is a 1991 with the Ford 351. This will be my first year of owning a MC and I had the local dealer winterize it for me. I am now putting it all back together and was wondering if the block had two plugs in it or just one. I can see by the starter on the starboard side that there is a threaded hole and one on the port side as well. Looking at the rust stains on the block the port side looks like it was the one with the plug. Can anyone help me out with this?
Old 03-08-2007, 10:23 PM
Kevin 89MC's Avatar
Lucky! Still snow & ice all over here. Sweet boat!
De-winterizing is fairly easy. There's likely a good post in the FAQ. Your block has two plugs, one starboard, one port, both below manifolds. Starboard one is toward the bow, port one toward the stern (I think, mine's still in storage). From the factory, they came with petcocks that you can open to drain, then shut when you're done. If you just have a threaded hole, you'll need to get some brass threaded plugs to seal them up. Or you can get the fancy brass shutoff valves from skidim (I have them-they work great). If the petcocks are there, open them to drain the antifreeze (put a bucket under your bilge drain to capture it). Then close the petcocks (or install plugs). Check to make sure your manifold drain plugs are in. Check to see if the impeller is installed (or put a new one in). That is in the front of the engine, right behind the pylon, held in by a round plate and 4 brass screws. Don't overtighten them-they snap easy.
Check to make sure all your hoses are hooked up. Make sure your exhaust flaps aren't taped shut. Throw it in the water & fire that bad boy up!
Old 03-08-2007, 10:30 PM
dmayer84's Avatar
dmayer84 dmayer84 is offline
Boat: Mastercraft X10 2004 5.7L
and its running
Old 03-08-2007, 11:56 PM
WAT8415's Avatar
Hmm, well either I only have one plug in the block or my local MC dealer lost a plug. I placed the plug on the port side right under the screen for the water pick up hose. There is a threaded hold on the starboard side right above the starter. I did fire her up in the shop and I didnt see any water coming out of that hole but I will go get a plug for it. Dang there is a lot of smoke on the first start up, had to disable the alarm system before it went off and the alarm company sent in the fire department.
Old 03-09-2007, 07:47 AM
TMCNo1 TMCNo1 is offline
Boat: Gone
Smoke is probably from the fogging and it will burn off real quick after the boat gets good and warm and you run some gas thru the engine. It really botherd me the first couple years at start-up, but finally realized it was just part of the experience the first time out each spring.
Charter Member Number 1
Quote: 2RLAKE,
Old 03-27-2007, 04:44 PM
wakescene's Avatar
wakescene wakescene is offline
Boat: 2001 Maristar 210VRS, LTR 330HP, ZeroFlex Tower, KGB Ballast, PerfectPass Wakeboard Pro,
I'm just putting the finishing touches on De-Winterizing Article that is the followup to this: http://wakeboardnj.com/winterize.htm. I'll post when it's complete and on the site.
KG
Old 03-27-2007, 04:58 PM
east tx skier's Avatar
Boat: 1998 Ski Nautique
I have my dewinterization checklist here.
Here are the drain plug locations.
Previous: 1993 Prostar 205
FAQ
Be kind. Have fun.
Old 03-27-2007, 05:01 PM
edwinfuqua's Avatar
edwinfuqua edwinfuqua is offline
Boat: Master Craft 1985 Prostar 190, 454 HO -425 HP, Stars and Stripes Blue
It's all good, good information that is.
Edwin
Old 03-27-2007, 05:02 PM
edwinfuqua's Avatar
Got one for the PC 454HO? Just kidding, but I'm glad you pointed out that his engine has 5 drain plugs. 1. the trans cooler
2. left block
3. right block
4. left exaust
5. right exaust
It is a V8 and has two water jackets for both the engine and exaust.
Edwin
Old 03-27-2007, 05:22 PM
By the way, if you're missing a plug, the block plugs are 1/4" NPT and the manifold plugs are 3/4" NPT. You can get brass replacement plugs at NAPA.
FAQ
Be kind. Have fun.
