Old 03-07-2007, 11:24 AM
causewayskiier causewayskiier is offline
Boat: 1992 MC Prosport 205, 285 HP
Engine block freezing
Anybody have an idea how cold it has to get and for how long before there is a risk of engine damage? I un-winterized my boat then the temp dropped to around 27 I think, just wondering If that is cold enough to do damage?
Old 03-07-2007, 11:27 AM
east tx skier's Avatar
Boat: 1998 Ski Nautique
Stored inside or out? When you dewinterized your boat, did you run the engine in the water or just get it ready for the water?
Previous: 1993 Prostar 205
FAQ
Be kind. Have fun.
Old 03-07-2007, 11:53 AM
JKTX21's Avatar
JKTX21 JKTX21 is offline
Boat: 1996 Prostar 190, 350 EFI, PP, 13th Floor Tower
Ooops, the link I wanted to post has been deleted.
If your boat was indoors, it would have to be 27 degrees for a pretty long time to freeze your block. If the temperature just went down to 27 for the night, you should be ok.
"I'm too drunk to taste this chicken."
Old 03-07-2007, 12:31 PM
Skibumtx's Avatar
Skibumtx Skibumtx is offline
Boat: Mastercraft Tristar, 89, 351
I had the same question, the temp in Woodville TX dropped to 24 overnight a week ago; the boat is in a sling/boathouse about 2 feet over 60 degree water. I figured it would be alright and I did not want to drive 2 hours each way to fix it.
What does it take to freeze a block? I would think it would take a couple of days where the temp did not get above 32. Not much of a chance to winterize the boat this year, temp has been in the 50s-70s almost all winter.
Old 03-07-2007, 12:46 PM
Leroy
There isn't a clear answer because there are so many variables.
Google expansion force of ice and similar terms for some interesting reading. The science says when Ice freezes it expands 10%.
Jim Stringer
Physiology, Palo Alto Medical Clinic, California One of water's most remarkable properties is that it expands when it freezes to a volume that is always 10% greater than in the liquid state. In other words, 10 cups of water put into the freezer is going to turn into 11 cups of ice when it freezes. This expansion takes place with tremendous force, as anyone knows who has left a full container of water with a tight lid in the freezer. The force is enough to burst the strongest water pipes if the water in them freezes, which is why people in cold climates sometimes leave a little water trickling through the pipes on freezing nights. It is not possible to make a usable pipe strong enough to withstand this force. Freezing water can burst a cast iron pipe over a foot thick. Water expands when it freezes because the molecules of water are actually closer together in the liquid state than they are in ice. Water molecules are polar, which means that they have positive and negative ends like little magnets. When water freezes, the molecules are held together in a rigid crystal pattern called a lattice, lined up with opposite charges next to each other. When the ice melts, the water molecules can tumble over each other and briefly get a little closer than they are in the solid crystal. This expansion is a very important phenomenon in the natural world. The force of freezing water is enough to crack open rocks and speed up the erosion of mountains. If water did not expand, then it would be denser when it froze, and would sink and soon cover the bottom of a lake or ocean. The oceans would fill with frozen water, and life as we know it in the oceans and on land would not be possible.
Old 03-07-2007, 12:57 PM
kpickett's Avatar
kpickett kpickett is offline
Boat: 1994 Prostar 190 - LT1
I haven't had a block freeze, but I talked about it with my mechanic. He told me that in his experience it needs to hit 26 degrees for three nights in a row to crack an undrained block....for what it's worth.
Old 03-07-2007, 01:10 PM
Bruce Bruce is offline
Boat: 1999 MariStar 230 VRS 5.7 Indmar Vortec
I am in the same boat (no pun intended) here. My boat is in a sling over water. I usually have lights in the engine compartment (V drive) to keep it warm. It warmed up I took out the lights closed the drain ran the engine with flush pro etc. Of course it turned cold again. 26 to 28 on a couple of nights. Local weather guy says 28 for four hrs. will freeze. I have observed that in my birdbaths. However, I don't think it is enough to bust a block. I guess I will find out in a couple of weeks.
"IT IS WHAT IT IS'
Old 03-07-2007, 02:02 PM
Jesus_Freak's Avatar
Jesus_Freak Jesus_Freak is offline
Boat: Past: 1994 PS 205 --> Now: Nothing
Originally Posted by Leroy
...If water did not expand, then it would be denser when it froze, and would sink and soon cover the bottom of a lake or ocean. The oceans would fill with frozen water, and life as we know it in the oceans and on land would not be possible.
Yes, and that is one of the many proofs God is amazing.
The biggest factor is time. How long does your boat experience x temperature? Environmental thermal changes have to diffuse into the water inside the block and then freeze some volume(s) of the water. These frozen volumes may be continuous or disperse. Obviously, to do damage, there has to be enough frozen to bridge a channel inside the block. In addition, I imagine that the crystalline structure of the frozen water (and hence its expansion compared to the liquid state) would have something to do with the rate at which it was frozen. So, I dont have the answer, but it can be solved.
Old 03-07-2007, 02:34 PM
Yea the boat was outdoors, with a cover on it, and an insulated motor box. I think the temp. was around 27 for 4-5 hours. I guess I'll know soon if everything is OK.
Old 03-07-2007, 02:46 PM
Prostar Rich's Avatar
Prostar Rich Prostar Rich is offline
Boat: Mastercraft Prostar 190 1990 351 Ford
4 to 5 hours would not be long enough to damge the block. You should be fine.
Prostar Rich
