#471
Prep the board in any manner you choose. I didn't do anything to mine other than to clean. The one trick I have read and also discovered after use is to put on a coat and let it soak for a couple of hours, tops. Wipe the excess off thoroughly and let the board set for another two days to completely dry. Repeat again after drying and apply a second coat (not saturate but apply to cover the board) and let that set for about two hours and wipe the excess thoroughly. Let dry for two days. Flip it and do the same on the other side. Seems tedious but the trick is to wipe the excess after just a couple of hours. No guarantees but I speak from satisfactory results with this method and material, as you can see in the picture. Other threads and posts here with similar testimony. $0.02
93 190 . Hypocrites, boot lickers, and crybabies…the world is full of them…. just look around - near-by . Duraflap / Kaydenco aren't worth a hoot Hose picture (internal) http://www.mastercraft.com/teamtalk/...68&postcount=8 . |
#472
Maybe I put to heavy of coats on mine.. I mixed linseed oil and mineral sprits 75/25, first coat looked great wet but soaked in and the wood was about halfway back to its old look.. I'll let it set a couple weeks and decide from there
Tapatalk
1990 prostar 190, 351, powerslot 1.5:1, tinted windows |
#473
#474
Thanks, I'll try to get a better picture tomorrow of how dark it is.. Might just be me!
Tapatalk
#475
+1 on the steel wool. I think it would be hard not to snag some of the wool on these boards.
#477
Brass wool is what works best without the stains
#478
That makes sense if you want to sand. I don't like sanding; so I don't.
At the risk of sounding a little (or a lot) stupid, wouldn't that get to be be a little slippery?? |
#479
If an X1 is the same I would be interested maybe but Utah is a long way from Texas.
#480
And I don't think the X1 and X30 use the same swim deck - but thanks!
