#391
Barefooter92,
i tried the steel wool, problem was the spotty layers that never got taken in by the wood became. sticky/tacky the steel wool just stuck to it and ripped apart andmade a bigger mess... tried light sanding... but then the deck was not uniform any more.... Sooooooooo! i got out my good old sander aaaagain and stripped it all i shall start all over from step one in the morning. this time i will make sure to watch for puddling where the teak is no longer taking it in. (2nd times a charm!) knock on teak |
#392
Hahaha Thanks for the Motivation, and i look forward to the ladies admiring my wood!
#394
It wouldn't hurt to hit it lightly with a sander again, like 220 grit to get it to take more oil, but not necessary.
If you're not into sanding it, just let it sit in the sun for a few days, it'll soak in. Any excess will be not noticeable and gone quickly once you hit the water anyway. Always leaves a nice little oil slick behind the boat for the first few hrs on the lake.
'06 X2 MCX "I understand why some people may not want to do this the way I have recommended but I can't understand the death grip some people have on a toilet plunger with a hose fitting." -JimN |
#395
#396
this is only and best thing to use,been doing it for over 15 years
-make sure its dry -sand with 400 -600 grit -hand sand,go with the grain -sanding will take 10-12 hrs,maybe more -vacuum clean -do not let it puddle -apply first layer -let dry 24-36 hrs -apply sencond layer -let dry 36-48 hrs -apply 3 layer -let dry 48-60 hrs once your done,it will look great,gives it a deep , rich look Star brite Premium Teak Oil http://www.starbrite.com/productdeta...Cat=Teak%20Oil |
#397
Go for it. I found a gallon of Daly's Seafin teak oil in a basement from the 60's... Worked Great.
Remember its just a swim platform, not furniture Scotchbrite then teak oil. Repeat as needed |
#398
Yesterday i finished sanding off the first attempt which turned out gummy and nasty. i put a new coat on last night and after about 20 min i took a rag and whiped it down to take off what wasnt soaking in. it came out pretty good. ill post a picture when i get a chance.
** check this idea out** before throwing the oil on last night a friend of mine said "you should get a brand made up that says mastercraft heat it up and then burn it into the center board of the deck. then stain over it." basicly engraving the teak. i thought it was a kinda cool idea. VERY RISKY though if you mess up, really only get one shot at it. has any one ever attempted this or thought about doing it? |
#399
haha maybe next year, i had a hard enough time just re finishing the teak. at this point with my luck ill try and brand it and all the oil/stain will go up in flames haha
