  #191
Old 03-07-2010, 08:46 AM
TMCNo1 TMCNo1 is offline
Boat: Gone
Originally Posted by Jesus_Freak View Post
Looks excellent. Question: Seems like Harold's method (dont have time to find it now) includes dry sanding and eventually wet sanding after coats of oil are being applied. How do you keep from mucking up the sandpaper with oil? I tried to sand mine 3 weeks after the first coat "dried", and I cannot get through but about 4 seconds of sanding before my sheet is toast. What am I missing?
Having the sandpaper gumming up is a result of one of two things, one the oil is not dry enough and/or you need to wet sand using soapy water to allow the liquid to keep the sanding debris washed out of the sandpaper. The dry sanding should only be performed when the wood is dry and has not had any oil applied to it to be able to sand away the fuzzy raised fibers of the wood after the wood has dried and make it the last step other than taking a tac rag to it to remove the dust just before the first coat of oil is applied.
Charter Member Number 1
Quote: 2RLAKE,
Old 03-07-2010, 09:20 AM
bbymgr's Avatar
bbymgr bbymgr is offline
Boat: 2007 X1, RTP
I had the same problem the first time a did #1's program. I bought a Wet Wedge to keep the paper fully wet and keep it from gumming up. Never had problems after that.
http://wetwedge.com/evanhorvath.htm
"In conflict, straightforward actions generally lead to engagement, surprising actions generally lead to victory."
Six in, Six out.
2007 MasterCraft X-1, CHARCOAL Black
Old 03-07-2010, 09:24 AM
Great product - I have never seen one of these before. I will definitely be ordering!
Old 03-07-2010, 09:30 AM
JohnE's Avatar
JohnE JohnE is offline
Boat: 40th Anniversary X14
Damn, 50 and sunny here today. Y'all gonna shame me into putting a coat on the platform today.
40th Anniversaary X14
Prior boats - 2009 X14, 2008 X14, 2005 197, 1997 Prostar 190, 1988 Tristar 190, 1989 Prostar.
Old 03-07-2010, 10:59 AM
Boat: No Boat
36 wiht rain forcasted for the week.
Tim
Old 03-07-2010, 11:28 AM
Skipper
Use very thin coats of oil and plenty of water for lubrication. It is an exercise in repetition.
It does need to be 65f at a minimum.
You can make sure that the oil is dry enough and that you are using enough water by conducting a simple test. First, determnine the coefficient of friction of the sand paper across dry, oil free teak by calculating the amount of force required to pull the sanding block across a preset distance. Then, carefully spray water on the surface of the oil free teak and repeat the test. Now, apply oil in a sealed room at 80f with .05% humidity and let it dry for two months. Then, calculate the coefficient of friction without using water. Next divide the coefficient of friction of the sand paper across the dry teak oil by that of teak with no oil multiplied by 3.14 multiplied by the coefficient of friction when using water on teak without oil. If the result is within .0631% then the oil is dry enough and you are using enough water. Simple, really.
Old 03-07-2010, 11:36 AM
trickskier's Avatar
trickskier trickskier is offline
Boat: 2006 X-1 MCX
Looking good Too-Tall!
The Only Thing That You Can Give and Still Keep Is Your Word
Old 03-07-2010, 11:49 AM
JJMorris3 JJMorris3 is offline
Boat: Mastercraft Prostar 205
Swim Platform
I am surprised and excited about the results of oiling. Thanks for the advice Team Talk!
Old 03-08-2010, 02:03 PM
Jesus_Freak's Avatar
Jesus_Freak Jesus_Freak is offline
Boat: Past: 1994 PS 205 --> Now: Nothing
What else did you think I was doing? Actually, you left out a few constants and a partial derivative, but I know what you mean.
Seriously, thank you all for the clarifications. I need to revise my methods...
Life is fragile; Pray hard (click for prayer requests)
"Magna opera Domini exquisita in omnes voluntates ejus" - James Clerk Maxwell, physics pioneer, 1874
Old 03-08-2010, 02:14 PM
Skipper
I got you brother....
I used this technique on my teak. Ran into the same problem. Once you wipe or brush on the teak oil, wipe off the excess after about 15 minutes. It doesn't all get absorbed by the wood. Then it will dry faster. You really need a lot of water. Keep it wet while you sand. Very time consuming. Takes a bunch of applications.
