Old 01-10-2005, 02:24 PM
jayderwin1's Avatar
jayderwin1 jayderwin1 is offline
Boat: MasterCraft, ProStar 190, 1986, 351.
stalling motor
when i rev my motor up and slow it back fast it will kill the motor does any one have any suggestions my motor has carbs.
Old 01-10-2005, 03:14 PM
east tx skier's Avatar
Boat: 1998 Ski Nautique
Are you idling or in gear when you rev it up (it sounds like you're idling, but wanted to be sure).
Previous: 1993 Prostar 205
FAQ
Be kind. Have fun.
Old 01-10-2005, 03:36 PM
jayderwin1's Avatar
Question
for example when i back the boat off the trailer and i give it some gas to pull back then i move the throttle back to neutral when the boat gets off the trailer the motot will die. your probably think that the motor is still cold but it happens when the motor heats up to running temp about 170 although it does not happen so easily. the only thing i can think it might be is the idle is set to low. but to answer your question it will happen in idle or a neutral rev. can you think of anything it might be?
Old 01-10-2005, 04:15 PM
I had my share of carb trouble, but if you're in an older boat, which it looks like you are, we're now running the same carb.
Two things to at least consider if it's not been a while since your last rebuild is (1) fuel slosh and (2) heat sensitivity. Both were problems commonly associated with my 4010 Holley Carb. Then again, your idle might be low. If you've got a manual, it should tell you the idle range. Mine is at about 615 rpm. If I adjust it to about 510, it starts to stumble.
FAQ
Be kind. Have fun.
Old 01-10-2005, 05:04 PM
jayderwin1's Avatar
yours is 615 is that normal? my is about 400 so that may be the problem at least i hope i would hate to have to rebuild a carb.
Old 01-10-2005, 05:10 PM
Dan K Dan K is offline
Boat: 81 Stars & Stripes 351W and 1998 30th Anniversary LT!
If your idle isn't smooth it could also be a vacuum leak, I had a similar issue and I determined that my carb gasket was allowing air to suck in. I found it by spraying carb cleaner around the gasket slowly as the engine idled. If you get a surge it is from the cleaner being sucked in. either tighten the carb or replace the gasket. There are other sorces for vacuum leaks such as around the manifold.
Old 01-10-2005, 05:47 PM
615 rpm is within the normal range for my engine, which, according to my manual is 600--800 for both the 351 and the 351 HO.
FAQ
Be kind. Have fun.
Old 01-10-2005, 06:29 PM
André's Avatar
André André is offline
Boat: Prostar 190 1994
400 revs at idle seems low for any kind of engine...
Keep skiing!!!
Old 01-24-2005, 02:47 PM
jayderwin1's Avatar
how do you adjust the carb so it will idle higher?
Old 01-24-2005, 02:57 PM
There is an idle adjust screw on the port side of the carb about half-way back.
FAQ
Be kind. Have fun.
