Old 01-02-2007, 11:08 PM
shepherd's Avatar
shepherd shepherd is offline
Stereo dies
I have a new Alpine CDE 9852 head unit in my boat. Had it professionally installed with my new amp (which is wired to my 4 speakers). When it plays for a while it just dies on me, cycles back on, dies again, cycles back on, dies, etc...
It only really seems to happen at the higher volumes so I'm thinking there is some power overload going on.
So what do you think? Defective head unit?
Former boats:
1990 Prostar 190
Old 01-02-2007, 11:12 PM
Sodar's Avatar
Sodar Sodar is offline
Boat: '07 ProStar 197 w/ MCX
Same thing happens in our center console when the batteries get low... sounds like it is not getting enough power.
-Cameron
2007 ProStar 197
1996 ProStar 190
Old 01-02-2007, 11:16 PM
Monte's Avatar
Monte Monte is offline
Boat: 1986 Tristar 220 351 pcm
my thoughts exactly
Old 01-02-2007, 11:21 PM
shepherd's Avatar
Well I was hoping that was it, but the battery is showing a little over 12 volts on the multimeter (engine not running).
Former boats:
1990 Prostar 190
Old 01-02-2007, 11:25 PM
Monte's Avatar
Does it work with the boat off?? if so.. it could be that your alternator is not pushing enough juice..
Old 01-02-2007, 11:26 PM
beef beef is offline
Boat: MC Prostar 205, 1998
Does it have a removable faceplate? If so, check that the connections between the faceplate and hu are clean. You can use a pencil eraser to remove any dirt or corrosion. I had a similar problem that was fixed in this way.
Old 01-02-2007, 11:56 PM
shepherd's Avatar
Actually, the stereo is so new it's only been used with the boat off, while I've been working on it in the garage. That's why I first suspected low power, but the battery is still strong - I charged it up about a month ago.
There is a removable face plate, but it's a brand new stereo so there shouldn't be any corrosion. Also, I've never removed the face plate except to flip it down to insert a CD. But I'll check it anyway. Thanks for the suggestion beef.
Former boats:
1990 Prostar 190
Old 01-03-2007, 12:06 AM
Leroy
I'm with Sodar now, I think the battery is low. It's funny because they can trick you into thinking they are ok with no load. Sounds like a low bat condition. Charge up the bat again.
Old 01-03-2007, 12:11 AM
victorff's Avatar
victorff victorff is offline
Boat: mastercaft,x-9,2004
Were you having this problem before the amp was wired in?
It's all about the Ride!!
Old 01-03-2007, 09:47 AM
shepherd's Avatar
Yes I was. I hoped that the amp would fix the problem, and it seemed like it did for a while. But now it's doing it again. I have the battery on a slow charge now after seeing Leroy's and Sodar's posts. I always assumed the battery was strong if it showed 12+ volts on the multimeter without a load on it - didn't know that's not necessarily true. We'll see tonight when I try it again. Thanks again for the suggestions guys.
Former boats:
1990 Prostar 190
