Old 12-27-2004, 01:48 PM
H20skeefreek's Avatar
H20skeefreek H20skeefreek is offline
Boat: '85 Stars and Stripes
re-installation of impeller
when re-installing an impeller that has already been used, which way should the bent vanes go. I know i installed one backwards one time, and it wouldn't turn. trying to de-winterize for the weekend.
ITCHIN' TO SKI, LET'S GO!!
1985 MasterCraft Skier, Stars and Stripes
351W with PowerSlot and Perfect Pass
Click here if you need prayer, or wish to pray for those who do.
Old 12-27-2004, 02:00 PM
kjohnson's Avatar
kjohnson kjohnson is offline
Boat: 1991 Prostar 190
Impeller
It doesn't matter. As soon as you start the engine, the vanes will align themselves correctly.
Old 12-27-2004, 02:11 PM
cool, thanks!! When i did it before, i think the impeller had been in for a long time and had stiffened up. therefore, when i started the motor with them bent the wrong way, it gave too much resistance and didn't let the pump turn and realign them. this impeller is only 1/2 a season old.
Thanks!
Old 12-27-2004, 05:31 PM
G-man's Avatar
G-man G-man is offline
Put it in just before you go to the water. Coat it in silicone grease or binding lube so it has some lubication while it turns over. I twisted the impeller clockwise to get the veins in the correct orientation.
06 AWSA Approved Towboat
Old 01-05-2005, 01:24 PM
OhioProstar OhioProstar is offline
Boat: 1995 PS190
Send a message via AIM to OhioProstar
I just use dish soap....Silicone grease can still break down the rubber, can't it?
Old 01-05-2005, 01:46 PM
G-man's Avatar
Silicone grease will not break up or dry out black rubber. A oil base lubricant like WD-40 will in time break down rubber. Soap is fine also.
Old 01-05-2005, 06:06 PM
pdoppenheim pdoppenheim is offline
Boat: MasterCraft, Prostar 197, 2004, MCX, Tournament Team Edition
Think about a new impeller
A new impeller is cheap insurance. If a blade comes off the impeller, it travels through your cooling system until it reaches a place it can't transit and then it lodges. Yes, it can be acid boiled out, or blown out backwards, but do you really want to spend the time doing that instead of skiing?
Any impeller is slightly damaged by the puller when removing it. They are even more damaged by when screwdrivers and/or pliers are used to remove them. If your impeller is so old that the blades have taken a set, scrap it. They can be bought at an auto supply store for a lot less than the $40.00 the M/C dealers want. Auto parts price is $15.00 to $25.00. Get one at M/C then take it to your auto store and duplicate it.
Also, put on a new gasket with every new impeller. Don't forget the lube.
Old 01-05-2005, 08:22 PM
My impeller was new 2 months ago, took it out for winterization, but it back in when i decided to ski. and as far as damage with a puller, and '85 with a pcm requires no puller, or screwdriver for that matter. I lubed it up, and it turned the right way with no problems. I'm skiing tomorrow!!! SC weather is great!!
Old 01-05-2005, 09:59 PM
Jim@BAWS's Avatar
Jim@BAWS Jim@BAWS is offline
Impeller Backwards
You cannot put a impeller in backwards but... you can reinstall a waterpump housing the wrong way on a PCM motor. Mark the pump housing before you disassemble it. There is a small drain screw on the housing. Hope this helps
Jim@BAWS
Old 01-06-2005, 06:21 AM
Boat: 95 PS 190 EFI
.... They can be bought at an auto supply store for a lot less than the $40.00 the M/C dealers want. Auto parts price is $15.00 to $25.00. Get one at M/C then take it to your auto store and duplicate it.
Do you have any idea what I need to tell the guy behind the counter at the auto-parts store? I just always assumed it was marine only, so I always get mine from skidim.
If one day you're asked:
Will you say:
It's time to SKI.
