Old 12-04-2006, 08:14 PM
msauce msauce is offline
Boat: 2005 Prostar 197
HELP! Frozen Boat!
I hadn't fully winterized my 2005 prostar 197 according to the steps in the manual (remove hoses, drain water, add antifreeze, etc.) Prior to parking it in the garage last weekend, I did run the boat out of the water for a bit to clear the majority of the water out... I just hadn't drained the hoses yet. I store it in my garage in the winter and I never thought that temps just below freezing would freeze the boat inside the garage (10 degrees is a different story, not 30ish). If you really want to know... I thought I might get a few more "indian summer days where we could go for a quick run" (Not). At any rate, I went out to check on it tonight and some of the hoses are solid with "SOME" ice in them.
Did I majorly mess up my boat? I'm putting a space heater out there tonight to thaw the lines in order to complete the winterization. Anybody have any thoughts on damage done, winterization, etc.
Thanks.
Old 12-04-2006, 08:20 PM
6ballsisall's Avatar
Boat: None this week!
I'd say get that space heater in their asap! Keep it on until you can fully winterize.
MC's owned:
1986 Skier 19
1995 ProStar 190
2003 X-7
1994 ProStar 205 (current)
Old 12-04-2006, 08:33 PM
Chief's Avatar
Chief Chief is offline
Boat: 2006 Maristar 200VRS
I'm sure you are okay. Get in there and pull those knock sensors and drain everything, the anitfreeze can wait. If there is no water in any systems to expand then you should be fine.
2006 Maristar 200VRS MCX
KGB Ballast and all the works! (Once upon a time)
Tow Veh: 2010 Toyota Tundra
Bike: 2009 HD Street Glide
Beer:Ballast Point IPA's
Chief Petty Officer: "Results not excuses"
"You Can't Beat a Tree"
Old 12-04-2006, 08:34 PM
88 PS190 88 PS190 is offline
Get its temp raised.. then follow all procedures.
Old 12-04-2006, 08:36 PM
trickskier's Avatar
trickskier trickskier is online now
Boat: 2006 X-1 MCX
I would think that since the hoses are thinner than the block, the water would freeze in them before freezing in the block. Check the freeze plugs on the side of the block to see if any of them show signs of popping out.
The Only Thing That You Can Give and Still Keep Is Your Word
Old 12-04-2006, 08:41 PM
WTRSK1R's Avatar
WTRSK1R WTRSK1R is offline
Boat: 2004 MasterCraft ProStar 197
Add heat
At a minimum, put a light bulb under the motor box. A trouble light works well, but any light with a 60watt bulb will throw sufficient heat to keep everything just fine until you get the "full" winterization done. The sound proofing on the motor box will hold in a surprising amount of heat once you have the light in there. If it has only been one night, you probably have nothing to worry about.
Good Luck.
A positive attitude may not solve all your problems, but it will annoy enough people to make it worthwhile
2004 Prostar 197 - Red on White
350 TBI, Perfect Pass, Heater, Shower and a whole lot of fun!
Old 12-04-2006, 08:45 PM
One night... maybe two at the most. Once I get a little heat in there how do I make sure I"ve gotten all the water out? Shop vac on "blow" in the main intake hose?
Leroy
I hope you are ok. I would also guess if it is only one night it should be ok, but certainly not something to chance. So many variables can determine if you have a big problem or not.
Good luck
Old 12-04-2006, 08:51 PM
Farmer Ted's Avatar
Farmer Ted Farmer Ted is offline
Boat: 1998 Prostar 190
take the cover off the impeller remove all the hoses that are attached to the water pump
I'd skip blowing the hose thing
Old 12-04-2006, 09:03 PM
mash's Avatar
mash mash is offline
Boat: Prosport 205, 1993, 351 HO
Drain the exhaust manifolds, drain the block, pull the hoses on the raw water pump, drain the trans cooler, and the mufflers. You should have ware running out of the block and manifolds. If so your probably OK.
Trouble light as suggested earlier should do the trick if it's not too cold.
'93 Prosport 205
