Old 11-12-2006, 06:51 PM
Loffgren's Avatar
Loffgren Loffgren is offline
Boat: 2008 Mastercraft X2 MCX White/Blue
X1 or X2 prop "drive shaft removal"
How do I get the "drive shaft"out of the transmission? I am replacing packing gland...
Old 11-12-2006, 07:32 PM
TMCNo1 TMCNo1 is offline
Boat: Gone
Are you replacing the packing in the shaft log? There would be no reason to remove the shaft to replace the packing. Just pull it out with some dental tools and replace with 3 new pieces with the ends spaced 120 degrees apart or just add a piece to it. I seriously hope this is not being done on the '06 in your profile. We have a '89 PS190 and I have only added 1 piece in 18 years and 450 hours.
Charter Member Number 1
Quote: 2RLAKE,
Old 11-12-2006, 09:26 PM
point1234's Avatar
point1234 point1234 is offline
Boat: 2006 X1
It must of been from the mouse in his boat.
www.midwestwakeboarder.com
Old 11-13-2006, 11:58 AM
Loffgren's Avatar
re
It is a one piece packing gland, so the shaft has to come out to slide on the gland. Yes it was from the friggin RAT, thats all i have left to fix YEEEEEEEE
Old 11-13-2006, 12:54 PM
sanjuan23's Avatar
sanjuan23 sanjuan23 is offline
Boat: 1992 Prostar 205 w/351 H.O. 4 Blade CNC Acme
Maybe I missed it but I assume that the little monster has finally meet his/her demise...
1992 ProStar 205 351 HO Acme 4 Blade
"The only reason people get lost in thought is because it is unfamiliar territory."
Old 11-13-2006, 02:07 PM
Boat: Gone
Nevermind, I forgot about the critter!
Old 11-13-2006, 02:25 PM
Loffgren's Avatar
re
I have not found a carcass but he is not in there, could be under gas tank pulling that tonight
Old 11-14-2006, 11:11 AM
Loffgren's Avatar
OK Got shaft out heres how
Ok, so took the nut off the shaft end next to gas tanks remove the four nuts and bolts from brass/metal spline hub also next to gas tank.
Removed prop used shaft as a slide hammer to pop shaft from spline hub tada!!!
