Old 11-09-2006, 04:20 PM
BrianM's Avatar
BrianM BrianM is offline
Boat: 1988 Prostar 190
Heated Drivers Seat Install
Finally got the heated drivers seat installed in my '97 190 and figured I would post a little how to for anyone that might want to do the install. Overall the project took me about 3 hours and cost a total of $110.
These are the heaters I purchased http://www.sportsimportsltd.com/pedecafiunhe.html I was able to get them direct from the manufacturer off of Ebay for $75.
Here are a couple of photos of the heated seat kit. They have carbon fiber elements and are waterproof. High and Low heat settings with a lighted switch.
Old 11-09-2006, 04:21 PM
BrianM's Avatar
Here is a close up of one of the pads.
Old 11-09-2006, 04:23 PM
BrianM's Avatar
Now I had to remove the hundreds of staples that hold the skins to the seat backs. This took a total of about 1 1/2 hours do do. Had to be carefull not not tear the vinyl.
This is the seatback
Old 11-09-2006, 04:24 PM
BrianM's Avatar
And now to peal back the vinyl so that I could install the heater elements.
Old 11-09-2006, 04:27 PM
BrianM's Avatar
Now put the element in using the double sided tape supplied with the kit to keep the element in place while recovering.
Old 11-09-2006, 04:29 PM
BrianM's Avatar
Do the same for the seat bottom cushion. This required a little more dismantling since there were four seperate pieces of foam and the vinyl had flaps in order to keep the contours tight. I also had to trim the heater element to length.
Old 11-09-2006, 04:31 PM
BrianM's Avatar
In order to get the wire for the element out of the seatback at the proper location I had to drill a hole in the back for the wire to pass through. there was an existing hole on the seat cushion that I used.
Old 11-09-2006, 04:35 PM
BrianM's Avatar
Here I cut out a little piece of foam so the wire would sit flush and not show through the vinyl.
BrianM's Avatar
Now to re-attach the skins to the backs. I cheated a little here and had an upholstery shop do this for me. The black plastic that makes up the seat base is impossible to staple into without a neumatic stapler. I paid the guy $30 to restaple with stainless staples. Worth it since I didn't have the proper tool. If you have an older boat with wood bases you could easily do this yourself.
Old 11-09-2006, 04:37 PM
BrianM's Avatar
Now put the cushions in the seat frame and route the wires so that the seat can still slide to its full back position. You will hide these wires later.
