Old 12-16-2004, 03:04 PM
martini's Avatar
martini martini is offline
Boat: Mastercraft, Prostar, 1984, PCM 351, 1:1
Marine Carbs?
Has anyone considered, when carb replacement is required, using Edelbrock's marine carb? I'm mostly just curious because this was the route I chose to take when I had to make that decision. I have to say that I am very pleased with it and it's simplicity makes it even more attractive. I guess my question is, why don't we see more of this? Longevity argument aside(I have had no issues) why the bias to get the Holley 4160? The Edelbrock, with a tuning kit and extra gaskets, is still less expensive than the Holley. Just something I noticed with regards to carbs and our precious ski boats!
Old 12-16-2004, 03:55 PM
east tx skier's Avatar
Boat: 1998 Ski Nautique
I suppose it's because Holley was OEM on these boats and the 4160 was the more reliable and still available Holley carb. Second reason is probably that DIM stocks the Holley and they're a pretty popular source. I paid $419 for a new one last May (please disregard any previous posts in which I said $319 --- sorry).
Previous: 1993 Prostar 205
FAQ
Be kind. Have fun.
Old 12-16-2004, 04:48 PM
martini's Avatar
That is probably true and I guess price is really not an issue for most people who own boats, but I paid about a $100 less w/the tuning kit and gaskets. It fit perfectly and once I dialed it in, has been rock solid since. Only time will tell if longevity is an issue. I guess we will see. If you are a do it your selfer, such as I am, this carb makes more sense and the instructions it came with were excellent. You also don't have to remove it or fuel bowls from the engine to make adjustments to float level and jets. It worked for me and I think it looks coooool on the engine!
Old 12-16-2004, 05:19 PM
That's just it. I'm not that much of a do-it-yourselfer. The Holley I bought came pre-tuned for the 351W. The only thing I've done to it is adjust the idle.
As for longevity, I have information from an owner of a 4160 who went around 10 years before selling his boat and never required a rebuild. He just ran it about once a month during the winter (and, obviously, regularly during the summer). I've decided that it's not too much trouble for me to do the same (draining afterwards during the winter).
FAQ
Be kind. Have fun.
Old 12-16-2004, 05:37 PM
crdickey crdickey is offline
Boat: 2003 PS-197 - X7
If you just installed an Edelbrock manifold you'll need to tune you carb to match the increase air flow of your new high performance manifold.
Changing one without adjusting the other doesn't give you the HP boost you are looking for.
Edelbrock sells performance packages which are dyno match components, intake, carb, cam and heads. This is the best way to breath life into an older motor.
I did this to a 1987 351W PCM motor and basically it was a bolt on 150HP increase. Cost me $1,500.00
All this is posted on Edelbrocks website. This link should take you to the correct page. http://www.edelbrock.com/automotive/ford_1g.html
The only think that needs to be marine is the carb, everything else is the same as the automotive.
Old 12-16-2004, 05:50 PM
martini's Avatar
EastTX,
Not that it will be a concern for you, since your Holley was tuned for your setup(High Output set up with the GT40 heads), but in general, more air flow into the engine will require more fuel as well. Like I said, the intake shouldn't shoot you off into dangerously lean. But, I wonder what other performance you could gain with a little carb tuning to your new set-up? If this was already addressed by your mechanic, I apologize for sounding any alarms. It probably really wouldn't matter, unless you run at WOT all the time. I know that when I initially installed the Edelbrock on my boat, it was set way too lean. It would get hot at moderate cruising speeds, miss on full throttle, and generally run crappy. I enriched it 2 stages at WOT and 1 stage in the cruise range and all was good. Just a little something for you to chew on.
Old 12-16-2004, 05:51 PM
martini's Avatar
crdickey beat me to the punch. However, on that link you would substitute carb number 1409 in place of the ones they have listed.
Old 12-16-2004, 06:03 PM
Well, the boat's put up for now. When I have a chance to run it, I'll see what's what. Not alarmed, just glad to have good info.
My mechanic was of the opinion that Holley's tend to run a little rich anyway, and since the manifold wasn't a drastic change over stock that it would probably do alright. So the plan is to take it out, run it, and bring it back to rejet, retune, or whatever is necessary (if necessary) after we have a field test.
Sounds reasonable to me. Looking at the weather, Saturday is supposed to see the low 60s.
FAQ
Be kind. Have fun.
Old 12-16-2004, 07:32 PM
Storm861triple Storm861triple is offline
Boat: 1992 Mastercraft Prostar 190
I'm sorry, but I'm going to have to raise the BS flag all the way to the top of the pole BS flag pole here.
No WAY on this planet did you get 150 more hp from a cam and intake. I don't know where you got that number from, but that figure belogs on planet Jupiter, not Earth. You MAY have gotten as much as 30-40 hp if you're lucky, but no way did you see 4-5 times that much.
Again, for all reading this thread, a cam and intake will net you maybe 30-40 horse at the most!
Thomas Kendrick
'92 PS 190
Old 12-16-2004, 07:50 PM
As for the whole Edelbrock vs Holley debate, the holley is a better carb. I do agree that the Edlebrock has SOME FEATURES that are nice and well thought out, but it also has some terribly engineered and very cheap features as well. Examples are the goofy "flapper door" thing that Edelbrock calls vacuum secondaries. Another is the terrible veturi design (the secondaries don't even have a concentric shape!). Another is the fact that the throttle shafts are loose in their bores right from the factory! Built in vacuum leak! Lastly, the float bowl design lends itself toward fuel slosh and flooding during hard cornering and off angle operation (I thought this was a PERFORMANCE carb??)
I just went through all this crap on my 420 hp Camaro, and ended up resolving all the above mentioned issues with a Holley 4150, 700 CFM mechanical secondary carb. Much, much better, even if I do spill a little fuel when jetting it. (something you should only have to do once).
I personally prefer the 4150 over the 4160 because the 50 has a metering block for the secondaries which allows you to jet the secondary A/F ratio. The 4160 has a metering PLATE which is no longer available in diferent orfice sizes so tuning of the secondary A/F ratio is not an option.
Having said that, and a word about reliability, I still have the original 4160 on my engine, 12 years old w/500 hours and it still works absolutely flawlessly. All carbs are reliable if you just keep them clean and maintained.
Thomas Kendrick
'92 PS 190
