Old 10-24-2006, 12:38 PM
butter butter is offline
Boat: 1992 Mastercraft Prostar 205
351W Drain Locations
I drained the water from my block, manifolds, etc... last night. I could only find one drain on the block itself, toward the lower, rear, port side. This is the only one on the block I could find... is it the only one? ('92 205 w/ 351W HO). Thanks!
Old 10-24-2006, 12:42 PM
sanjuan23's Avatar
sanjuan23 sanjuan23 is offline
Boat: 1992 Prostar 205 w/351 H.O. 4 Blade CNC Acme
IIRC there are 2 on the back side of the block and two on the backs of the manifold risers as well. Easty knows all...
1992 ProStar 205 351 HO Acme 4 Blade
"The only reason people get lost in thought is because it is unfamiliar territory."
Old 10-24-2006, 12:43 PM
BradD's Avatar
BradD BradD is offline
Boat: MC Prosport 1992, 351 Windsor
Send a message via AIM to BradD
there is one on the front starboard side as well.
1992 205 ProSport
Connelly F1
Old 10-24-2006, 12:48 PM
88 PS190 88 PS190 is offline
the starboard one might be kind of hidden, look behind any hosing etc.
also make sure to drain the trans cooler and drain the lines.
Old 10-24-2006, 02:39 PM
east tx skier's Avatar
Boat: 1998 Ski Nautique
Two on the block, two on the rear of the manifold risers (below where the exhaust hoses hook up).
The one on the port side is just rear of midway on the block. On the starboard side, it is foward of midway on the block.
Previous: 1993 Prostar 205
FAQ
Be kind. Have fun.
Old 10-24-2006, 04:29 PM
Thanks for the info, everyone!
Old 10-25-2006, 07:30 AM
emnesto emnesto is offline
Boat: 2006 X45 LQ9
Where does the hot water supply for the cabin heater connect? If I use Fak-a-Lake to deliver anti-freeze, will it get to the heater core? Does the heater need to be turned on for cater circulation? Thanks for the info. Just trying to make sure I get everything covered in my first winterization.
2006 X-45 LQ9
2005 Yukon Denali
Old 10-25-2006, 07:43 AM
92 190 PS's Avatar
92 190 PS 92 190 PS is offline
Boat: 2008 197
Just a couple other things I would check
There is a small drain on the back of the housing that the raw water comes through first (not sure what the function of that casting is). Other drain on my 92 is on the muffler in the back of the engine in the center. Not sure if you have the same set up or not....
2008 Prostar 197
Old 10-25-2006, 09:11 AM
richardsoncd's Avatar
richardsoncd richardsoncd is offline
Boat: 1979 Stars & Stripes Skier
Easty, is this the same for my '79 Pleasurecraft? Plus how do I get antifreeze into the block, a fake a lake isn't an option with my trailer.
Thanks man.
"take it easy, if it's easy...take it twice!!!"
'79 Stars and Stripes (FOR SALE); 68" Connelly Concept
Old 10-25-2006, 11:36 AM
I just read that there may be 3 drain plugs on the PCM. I don't know this for a fact, but worth investigating. As I mentioned in my PM to you, you will probably be fine without antifreeze in the block, but if you decide to do it, drop me a line and I'll give you a run through that will cost about $10 in parts. But bear in mind, I've never actually done it myself as I don't bother with antifreeze in the motor.
As for the heater, you probably want antifreeze there. But I'm not familiar as to how to do that as I don't have a heater.
FAQ
Be kind. Have fun.
