Old 12-12-2004, 12:59 AM
_JR
Switch Panel
Anyone know where I can find the switch panel for a 94 ProStar 190?
The cover is plastic and has cracked in a few places...looking at removing the switches and having one made out of aluminum, but if I can find one, it would be easier!
Old 12-12-2004, 10:05 AM
Did you call Mastercraft yet?
An aluminum one would work better, but anodized tends to develop a weird color over time from UV and certain cleaning supplies. There are places in most larger cities that make panels for industrial applications and could duplicate the original. They should be listed in the phone book.
Old 12-18-2004, 06:15 PM
_JR
JimN -
Yep, called my local dealer, and they don't have anything that old...recommended removing the existing cover and having an aluminum one made, which I am considering...will advise!
Old 12-18-2004, 10:50 PM
rasmithaz rasmithaz is offline
Boat: 99 Prostar 205
You can get a duplicate made at a trophy shop made out of plastic they use for plaques. last one cost me 70 bucks.
Old 12-18-2004, 11:53 PM
tph's Avatar
tph tph is offline
TAP plastics sells plastic sheets with various textures and thicknesses by the square foot if you are handy with a scroll saw.
Old 12-21-2004, 01:40 AM
_JR
Thanks for the good ideas guys, I will look into it!
Old 01-13-2005, 10:45 PM
Bongo Bongo is offline
Boat: 2004 MasterCraft 197 TT
JR
Any updates on your attempts to find or fabricate this switch panel? Please share what you've found, if there's been any updates.
I have an '89 MasterCraft and the corners of the panel have cracked or broken off.
Bongo
Old 01-17-2005, 08:55 PM
_JR
At the moment, I have taken the lazy way out and have used some finish washers to secure the panel in place.
I have contacted a local machine shop, and am waiting on them to give me a price to machine a replacement part from aluminum and to engrave the desired labels for each switch.
Will advise once I get more info.
Old 08-29-2006, 11:45 PM
mrG's Avatar
mrG mrG is offline
Boat: 1992 Prostar 190
I had a similar problem. The corners of the switch face plate cracked off leaving a poor appearance. I decided to try using #8-10 black plastic screw covers to hide the broken corners. I found these at my local Lowe's home center in the specialty hardware section.
After installing them on the corners I decided to add them to all the face plate screws to make it look uniform. An added benifit of using these is that they act as washers which seems to reduce stress on the remaning screw holes on the face plate thus, hopefully, preventing further cracking.
I'm happy with the way it looks now and it's certainly a lot easier, and less expensive, than having one fabricated.
Old 08-30-2006, 04:27 AM
Ryan's Avatar
Ryan Ryan is offline
Boat: 2007 SANTE 220
I got a template from someone on here once. They applied a carbon fiber-looking decal over a sheet of plastic.
I'll have to dig around for that file.
