Old 09-25-2006, 01:00 PM
beatle78 beatle78 is offline
Boat: 2001 Prostar 205V
Winterizing a '01 LTR (330HP)
Hi guys,
On my Malibu I always drained the block then ran Pink RV Antifreeze through it and left it in there for the winter.
The LTR is Differetn from the LT-1 correct? From what I've read here in the forums, the LT-1 has aluminum heads which don't like the pink antifreeze, but it seems like the LTR will be fine with the Pink Antifreeze in it......
thoughts?
thanks,
beatle78
Old 09-25-2006, 01:41 PM
Kell's Avatar
Kell Kell is offline
Boat: 2009 X2, MCX
That is my understanding as well Beatle78.
Old 09-27-2006, 12:51 PM
thanks Kell, anyone else have any advise to add?
Old 10-09-2006, 07:52 PM
bump..... I'm guessing most of you have the good fortune of not having to winterize?...... My jealousy ->
Is Pink anyfreeze ok to use in the LTR?
Anyone?
Old 10-09-2006, 08:22 PM
dsoby's Avatar
dsoby dsoby is offline
Boat: 2002 X7, LTR
Why don't you just drain the engine? I used to pump anti-freeze but draining is much easier and faster.
Old 10-09-2006, 09:07 PM
I guess I'm scared to DEATH of having water somewhere in the engine causing a crack .....
On mu BU, I actually drain the block, impeller hoses, and the tranny hoses, the I start it back up and fog it while I'm sucking antifreeze in.....
Old 10-09-2006, 09:12 PM
6ballsisall's Avatar
Boat: None this week!
Do what you are doing above ^^^^^^ As for antifreeze I don't know but am pretty sure pink is ok in the LTR. Ask JimN for clarificaiton.
MC's owned:
1986 Skier 19
1995 ProStar 190
2003 X-7
1994 ProStar 205 (current)
