Old 09-25-2006, 09:30 AM
skilew skilew is offline
Dead Spot Around 3100 RPMs
My boat has a 1993 Ford 351 engine (Carburetor). It runs great except when I get into the 3100 to 3200 rpm range and then I hit a dead spot (runs extremely poor) once I get above 3200 rpms the engine runs well again.
Is this a carburetor problem or an ignition issue? Any suggestions would be greatly appreciated?
skilew
Old 09-25-2006, 10:07 AM
92 190 PS's Avatar
92 190 PS 92 190 PS is offline
Boat: 92 Prostar 190
Not sure if it's related.....
A buddy had a similar issue on his 93 and chased if for a couple weeks...I think there is even a post on here for his...In his case it was the check valve out of the gas tank that was clogged...There is a 90 degree elbow on the top of the tank (where the fuel line comes out of the top of the tank) that and for some reason this was an issue for a couple folks on this site....He cleaned and flushed that and boat has run well ever since. Simple and worth checking before you go through anything else...
92 PS 190, 351 HO
Old 09-25-2006, 10:11 AM
east tx skier's Avatar
Boat: 1998 Ski Nautique
Interesting about the check valve. My boat has a flat spot at 2,175 rpms. If I run it there for a few seconds, the rpms will drop, then return repeatedly. You don't feel it under normal accelleration. I'd wondered if it was a vacuum leak.
Previous: 1993 Prostar 205
FAQ
Tyler Ski Club
92 190 PS's Avatar
Here are the links to his issue...Good luck
Starving for fuel thread....
http://www.tmcowners.com/teamtalk/sh...ad.php?t=10801
Fuel pump thread...
http://www.tmcowners.com/teamtalk/showthread.php?t=9783
92 PS 190, 351 HO
Old 09-26-2006, 02:08 PM
I removed the gas tank check valve and it appeared to be clean and work properly. I recleaned and installed but it did not fix my problem. Should I go ahead and replace this check valve anyway?
skilew
Old 09-26-2006, 02:17 PM
How are your gaskets (don't know that this is a problem, but wondering since I suspect I may be due for a switch and it might be causing my flat spot).
FAQ
Tyler Ski Club
Old 09-26-2006, 02:27 PM
LakePirate's Avatar
LakePirate LakePirate is offline
Boat: Tristar 190, 1989 / Maristar 210 2002
Send a message via MSN to LakePirate
Does the 93 still have points?
It's Snowing in the UP
Old 09-26-2006, 02:31 PM
Electronic ignition was standard in 93.
FAQ
Tyler Ski Club
Old 09-26-2006, 07:42 PM
Does not have points and gaskets are in good shape.
Old 09-26-2006, 08:22 PM
Jim@BAWS's Avatar
Jim@BAWS Jim@BAWS is offline
Secondaries not opening properly
That 3100-3200 PRM range is where you secondaries are susposed
to open kikcking in the 4 barrels. Run the boat with the motor box
open with the flame arrestor off and see if they are kciking in
Jim@BAWS
