Old 09-14-2006, 05:09 PM
3event's Avatar
3event 3event is offline
Boat: 2002 PS197
Shaft / Engine alignment
Looking for advice - is this recommended at 100hr intervals as my dealer says? Boat is at 225hrs, not been done yet. Charge $160. The year end service bill is adding up rapidly.
Wow, winterization more than doubled to $250 without oil change-ouch!
I wont short change the beloved MC, but I want to be sure what I am paying for .... any opinions appreciated. ...
2002 ProStar 197
Old 09-14-2006, 05:32 PM
JimN JimN is online now
Have them quote you a price based on actual time. They may have a flat rate book and/or the MC time sheets but I don't think I ever needed the max for an alignment. If they're quoting for the shaft/strut/motor/coupler, I can see this price. Ask them exactly what they will be checking/aligning.
Old 09-14-2006, 05:35 PM
3event's Avatar
Boat: 2002 PS197
Thanks Jim, I can now ask a question that makes some sense.
Does every 100hrs sound correct for alignment check? I just realized this year that my manual does not have maintenance intervals, so I have relied on each of the dealer's recommendations. Some are standard, it appears some are not.
2002 ProStar 197
Old 09-14-2006, 10:21 PM
The maintenance intervals used to be at the back of the manual- if you need to, you can contact MC and get them.
Old 09-14-2006, 10:29 PM
skilew skilew is offline
Ask to what tolerance that he is checking the shaft and coupling alignment (should be 0.002" to 0.003"). How is he checking this alignment using a laser or dial indicator or feeler gauges?
Old 09-15-2006, 10:40 AM
Tom023 Tom023 is offline
Boat: 2001 X30 LTR
Do a search on these forums and read about it some and decide if it's something you feel you can do yourself. I learned a lot about my drivetrain by replacing the cutlass bearings and aligning the driveshaft. It's not that hard to do and you know it's done correctly. After speaking with my dealer about it, I did not have any confidence they would take the time to get it to spec.
2001 X30 LTR
