Old 09-06-2006, 01:55 PM
etakk7's Avatar
etakk7 etakk7 is offline
Boat: 2000 ProStar 205V
Winterization of heater core/lines
Question: Does drawing in antifreeze through the raw water intake and running it until circulated also then circulate through the heater core/lines, or are additional procedures necessary for winterizing the heater? The boat is a 2000 205V.
Thanks
Old 09-06-2006, 02:12 PM
bigmac bigmac is offline
Boat: 2004 Maristar 230 VRS
Thanks
Nope, not necessarily. Best bet IMHO is to disconnect the most convenient heater hose line and pump RV antifreeze through it til it comes out the other hose into the block. I use one of those cheap anti-freeze RV winterization pumps. Next best bet is to blow a lot of air through one of the heater hoses.
'04 MariStar 230VRS/MCX
Old 09-06-2006, 02:37 PM
SD190EVO's Avatar
SD190EVO SD190EVO is offline
Boat: 2001 Sammy Duvall 190 EVO
Here in Colorado where it can get cold cold cold I always disconnect both lines of the heater at the block - I drop the lowest one in the bilge and put my lips on the other one and blow like crazy till I hear no 'percolatin'.
"You know who that is? That's Mr. Evil Knievel. He snuck in my back door, son, when I wasn't lookin'."
Old 09-06-2006, 02:47 PM
etakk7's Avatar
Thanks guys - second question - does anybody know the automotive replacement heater core for a 2000 205V? Mine does nothing but blow cold air, the previous owner probably forgot to winterize the heater.
Old 09-06-2006, 02:54 PM
I've heard of guys doing that - replacing with an automotive core, also taking the old core to a radiator shop for repair. Personally, my inclination would be to go to HeaterCraft directly. Word is that they're very responsive and customer-oriented.
Old 09-06-2006, 03:29 PM
beef beef is offline
Boat: MC Prostar 205, 1998
I went up to Lowes and got a couple of brass two way garden hose adapters along with some 5/8 fittings. Installed on both lines, along with a couple of short pieces of heater hose on the "open" ends. By reversing the open side of the Y, you can quickly blow out and/or pour full of antifreeze for those cold nights. This works really well if you want to keep sking into questionable temps.
It also has the added advantage of being able to easily shut off the heater in the hot weather, turning it into a nice cool fan for use while switching skiers. Total cost, about $15.
Old 09-06-2006, 03:44 PM
CoFooter CoFooter is offline
Etak,
When I forgot to winterize my heater, it actually ruptured and leaked all over the next spring. If its only blowing cold air seems like there may be a blockage issue or its hooked up incorrectly. Never heard of a core getting blocked when frozen unless there is still ice in there. The guy in the shop that replaced it recommended blowing through the line with your mouth to winterize it. You can tell if it is blocked by doing that.
Old 09-06-2006, 03:52 PM
My boat came with a nice little valve on the manifold side of the heater circuit for shutting off water flow through the heater circuit. Can't say I've ever used it, but it seems like a nice touch.
Old 09-06-2006, 07:37 PM
Boat: 95 PS 190 EFI
When mine froze, it ruptured. I took it to a radiator repair shop for a fix.
When you say it's blowing cold air - is that also while you are under way (> 2000 RPM's)?
If it's hot when above 2k RPM's, but cold while idling, you simply need to install a Y adapter available from www.skidim.com
If one day you're asked:
Will you say:
It's time to SKI.
Old 09-06-2006, 07:52 PM
etakk7's Avatar
No, it's cold all the time.
