Go Back   TeamTalk > General MasterCraft Topics > MasterCraft In Your Area
Old 08-28-2006, 03:26 PM
rkfitz
Cool Gel coat Blistering
I own a 1993 prostar190 I keep it on the lake full time. I pull it out about once a month to clean the hull. I notice this last time ,what seems to be small blisters on the bottom left side of the hull. What could be the cause of this and can I repair or be concerned.
Old 08-28-2006, 04:04 PM
G-man's Avatar
G-man G-man is offline
It can be repaired but gel coat without the protection of antifoulant paint is known to develop blisters. It is not a recommended practice in the owners manual.
06 AWSA Approved Towboat
Old 08-28-2006, 04:12 PM
mitch's Avatar
mitch mitch is offline
Boat: 2000 PS205/1999 Manitou 24' party barge
It's called osmosis
check here for further discussions> http://www.tmcowners.com/teamtalk/se...earchid=511983
Old 08-28-2006, 04:32 PM
bigmac bigmac is offline
Boat: 2004 Maristar 230 VRS
It's a well-known problem for boats kept in the water.
In the 1993 owner's manual for your boat, MasterCraft mentions blistering of the gelcoat on boats left in the water for extended periods and they specifically exclude gelcoat blistering from their lifetime hull warranty. They recommend a good quality bottom paint to minimize that problem.
'04 MariStar 230VRS/MCX
Old 08-28-2006, 04:40 PM
rkfitz
Thanks
Thanks for the info. I'll look into doing that over the off season after Labor day. I Love my MC and plan to keep it in mint condition. I have a place at Lake Hartwell in Georgia and paln to have a lift in my dock by next spring. That should help also.
Old 08-28-2006, 05:47 PM
88 PS190 88 PS190 is offline
Bottom paint is a well known way to stop blistering.
But it also immediately destroys the resale value of your boat.
Using a lift should keep the blisters at bay as it allows the gelcoat to dry, and essentially like using a trailer, just be sure to lift it all the way up.
Old 08-28-2006, 06:04 PM
There was a post here awhile ago from juju151 that developed blistering exactly where his hull rested on the carpeted bunks of his trailer. On my boat lift, I have full-length ridged poly bunks, so no holding water next to the hull.
Old 08-28-2006, 06:06 PM
MasterCraft has been addressing this issue for awhile.
Old 08-30-2006, 08:43 AM
mrG's Avatar
mrG mrG is offline
Boat: 1992 Prostar 190
Here is an explanation of the "blistering" process:
http://powerboat.about.com/od/hulls/...at_vswater.htm
Old 09-27-2006, 05:57 PM
boatless boatless is offline
This is some thing I don't understand, boat is made to be put in the water. Yet the industry are telling us not to do that so often cause it will cause blister to the bottom of the boat. I think boats that has blisters to the bottom are those that has its bottom redone at the factury or some time before the customer bought it. When that happen, the quality of the new paint or gel coat does not have the same quality as the first gelcoat and that caused blisters. Just a thought.
boatless.
