Old 08-24-2006, 12:13 PM
ski_king's Avatar
ski_king ski_king is offline
1. Max RPM at Wide Open Throttle 4600
2. Max Speed at Wide Open Throttle 46
3. Year of Boat1982
4. Manf. & Model MC 19Skier
5. EnginePCM 240 HP
6. Transmission gear ratio1.52:1 Powerslot
7. Prop dimensions (# of blades and pitch)14 x 18
8. Octane of fuel
87
9. Normal operating Elevation1000 ft.
10. Anything else you want to add that may make performance differentAdded electronic ignition, everything else is stock. Boat weights 2200 lbs.
STARS AND STRIPES FOREVER
Old 09-16-2006, 01:03 AM
PendO's Avatar
PendO PendO is offline
Boat: 06 197 1.26:1 MCX (Gone but not forgotten)
1. Max RPM at Wide Open Throttle -----------------4850
2. Max Speed at Wide Open Throttle ----------------44
3. Year of Boat ---------------------------------------------2004
4. Manf. & Model ----------------------------------------MC X-Star
5. Engine-----------------------------------------------------L-18
6. Transmission gear ratio-------------------------------1.5:1
7. Prop dimensions (# of blades and pitch)---------13.7 X 22 (nibral)
8. Octane of fuel--------------------------------------------92
9. Normal operating Elevation--------------------------2062
Switched props to 13.7 X 17 and got 5400 (rev limiter and 42 mph-but a larger pitch prop will be the key)
Clearly the boat is overpropped as it cannot get to max RPM's wth the 22, next spring we are going to try a 19.5 pitch from OJ and also try prop from Acme ... the original OEM prop was SS but cracked during the first season and was replaced on warranty with the 22 pitch OJ
At least you know one person who collected from the Cash Rewards program
Old 09-16-2006, 01:14 AM
PendO's Avatar
1. Max RPM at Wide Open Throttle ....4750
2. Max Speed at Wide Open Throttle ......42.5
3. Year of Boat ....2006
4. Manf. & Model ....MC 197
5. Engine ....MCX
6. Transmission gear ratio ....1.26:1
7. Prop dimensions (# of blades and pitch) ....13.7 X 15 (nibral)
8. Octane of fuel .... 92
9. Normal operating Elevation ....2062
planning to try a prop swap next spring to get closer to 5200 rpms, I have lost 100-150 rpms a WOT but I do have a slight ding on the prop
Old 09-17-2006, 02:09 AM
cwright's Avatar
cwright cwright is offline
Boat: MasterCraft Prostar 190 1988
1. Max RPM at Wide Open Throttle 4200
2. Max Speed at Wide Open Throttle 42
3. Year of Boat 1988
4. Manf. & Model PS190
5. Engine iNDMAR 351
6. Transmission gear ratio 1:1
7. Prop dimensions (# of blades and pitch) 13x13 Nibral
8. Octane of fuel 89 octane usually, sometimes 91
9. Normal operating Elevation 300
10. Anything else you want to add that may make performance different: Electronic ignition
Old 09-17-2006, 11:08 PM
6ballsisall's Avatar
Boat: None this week!
Top speed w/ 5 people in the boat and one footer was 44-45 mph this weekend. Pulling triple footers and no passengers top speed is 43 mph.
MC's owned:
1986 Skier 19
1995 ProStar 190
2003 X-7
1994 ProStar 205 (current)
Old 09-17-2006, 11:55 PM
edwinfuqua's Avatar
edwinfuqua edwinfuqua is offline
Boat: Master Craft 1985 Prostar 190, 454 HO -425 HP, Stars and Stripes Blue
1. Max RPM at Wide Open Throttle -5800 NO LOAD + clean water
2. Max Speed at Wide Open Throttle - did not hold it that long but my radar gun said 49 MPH at 5000 RPM
3. Year of Boat 1985
4. Manf. & Model MC PS190 Barefoot special Stars and Stripes
5. Engine Pleasure Craft 454 HO - totally rebuilt w/ rollor cam.
6. Transmission gear ratio 1.5:1
7. Prop dimensions (# of blades and pitch) 13.5x19.5 4 Blade OJ CNC
8. Octane of fuel 89+
9. Normal operating Elevation 600 Ft.
10. Anything else you want to add that may make performance different - 400 Ft Lbs tork from 1100 to 6000 RPM, 420 HP at 4200 RPM. Balanced and ready for a blower (Rods are rated at 750 HP and Stainless non welded valves) but I like it the way it is, heck 50 MPH and you hit a big wake - you better have your hand on the throttle and back off. I've allready got too many Gelcoat spider webs now.
I'm using straight exaust pipe, 4" OD all the way. I lifted my box 1/2 inch in the front (closest to the tow bar) eventually I will lift the entire box 1/2" front to back. This winter I am going to make SS exaust primary pipe from the manifold to the exist straight pipe, install another back flow device inside just before the inserts and couple it all togather with the existing rubber (got to have some flex), I'm going 'down under' style.
Edwin
Old 09-18-2006, 12:33 AM
edwinfuqua's Avatar
I have the original prop 3 blade 14" was modified from 18 to 20 pitch. I could get Red Line 6K RPM. I changed it to a 14.5x22 4 blade it was a little sluggist out of the hole and could only get about 4.3K RPM. OJ sent me a new prop and I'm thinking I like it. It is a 14"x19.5 4 blade CNC. I get higher RPM, better econonmy and it's still strong on the take off. My son was pulling my big fat $## up and he said he hit 4K. As soon as I got up I went head over heals. I guess he should have backed off a little when I surfaced. Props, Props, Props .... I think the one I have now needs to have a little more cup, say 20 or 21, but the 22 would not get above 4300 RPM and it seemed slugish. I still haven't seen +50 MPH no matter, it seems like that is all she'll do no matter what prop. That little 3 blade 14x20 SS that was modified would do some weird stuff. You could be going 35 MPH turn make a 180 turn and she was strong, jumping out of the water. Maybe that's why when I purchaced the boat it had a blown engine. 6K was nothing and I blue'd the SS prop the first day. Cavatation.
We seak power, no cavation except under extream load, no redline RPMS and performance. This has been fun.
Edwin
Old 09-29-2006, 01:29 PM
3event's Avatar
3event 3event is offline
Boat: 2002 PS197
BUMP, finally checked her out on last day of season
1. Max RPM at Wide Open Throttle: 4400
2. Max Speed at Wide Open Throttle: 47.3mph on PP and analog
3. Year of Boat: 2002
4. Manf. & Model: PS197
5. Engine: Predator 310 EFI
7. Prop dimensions (# of blades and pitch) 3 blade 14 pitch
8. Octane of fuel: 89octane EPA spec reformulated cr*p for SE WI
9. Normal operating Elevation: great lakes level
10. Anything else you want to add that may make performance: recommendations welcome!!!!
Thanks PENDO for a very interesting thread. I have considered it , but have NOT hooked the hull on this boat. I am not sold on trading wake for footing speed.....
2002 ProStar 197
Old 09-29-2006, 02:40 PM
JohnnyB's Avatar
JohnnyB JohnnyB is offline
Boat: 2004 Prostar 190
7. Prop dimensions (# of blades and pitch) stock 3blade (sorry couldnt read pitch last time checked it and keep forgetting to look....)
I'd be curious to know what prop you're running....
2004 Prostar 197, ACME 843
Old 09-29-2006, 02:42 PM
starman205's Avatar
starman205 starman205 is offline
Boat: 2004 Prostar 197TT
1. Max RPM at Wide Open Throttle:4600
2. Max Speed at Wide Open Throttle:43mph (gps)
3. Year of Boat: 1993
4. Manf. & Model:MC, PS205
5. Engine: 351 Ford, 285hp
6. Transmission gear ratio: 1:1
7. Prop dimensions (# of blades and pitch): 4 blades, 13X13 OJ
8. Octane of fuel: 92
9. Normal operating Elevation: water level-890 ft
