Old 08-20-2006, 10:05 AM
PendO's Avatar
PendO PendO is offline
Boat: 06 197 1.26:1 MCX (Gone but not forgotten)
WOT - Speed / RPM / Prop / Elevation / Octane / Year / Hull
Okay, I would like to compile a list, only because it matters to me and perhaps others. If you would be so kind (inboards only)
1. Max RPM at Wide Open Throttle
2. Max Speed at Wide Open Throttle
3. Year of Boat
4. Manf. & Model
5. Engine
6. Transmission gear ratio
7. Prop dimensions (# of blades and pitch)
8. Octane of fuel
9. Normal operating Elevation
10. Anything else you want to add that may make performance different
It will be interesting to see how boats with the same setup compare.
At least you know one person who collected from the Cash Rewards program
Old 08-20-2006, 10:11 AM
bigmac bigmac is offline
Boat: 2004 Maristar 230 VRS
1. Max RPM at Wide Open Throttle-------------5250
2. Max Speed at Wide Open Throttle--------------49
3. Year of Boat--------------2004
4. Manf. & Model---------------MC 230VRS
5. Engine--------------MCX
6. Transmission gear ratio----------1.5:1 V drive
7. Prop dimensions (# of blades and pitch)---------------Acme 847 4 blade 13.5x17.5
8. Octane of fuel------------91
9. Normal operating Elevation-------------2000ft
'04 MariStar 230VRS/MCX
Old 08-20-2006, 10:20 AM
JohnnyB's Avatar
JohnnyB JohnnyB is offline
Boat: 2004 Prostar 190
1. Max RPM at Wide Open Throttle - 4500RPM (Mfg range is 4400-4800)
2. Max Speed at Wide Open Throttle - 43mph per gps
3. Year of Boat - 2004
4. Manf. & Model - PS197
5. Engine - Predator 5.7TBI
6. Transmission gear ratio - 1:1
7. Prop dimensions (# of blades and pitch) - 3 blade ACME 843 13x12 0.080
8. Octane of fuel - manual suggests mid-grade, but I always run 93
9. Normal operating Elevation - whatever elevation Wisconsin is?
10. Anything else you want to add that may make performance different - ACME offered to tune my prop further if the stock 13x12 didn't meet my needs
2004 Prostar 197, ACME 843
Old 08-20-2006, 01:27 PM
Upper Michigan Prostar190's Avatar
Upper Michigan Prostar190 Upper Michigan Prostar190 is offline
Boat: 1991 mastercraft Prostar 190, 351 w/powerslot. Blue & grey.
1. Max RPM at Wide Open Throttle 4500
2. Max Speed at Wide Open Throttle 43 MPH
3. Year of Boat 1991
4. Manf. & Model Mastercraft Prostar 190
5. Engine 351 240 HP
6. Transmission gear ratio 1.5:1 powerslot
7. Prop dimensions (# of blades and pitch) 4 blade acme #275 13.5 X 17.5
8. Octane of fuel 93
9. Normal operating Elevation In my beset Chong voice, "Oh we ski right on the water Maaaan, no elevation...." 600 ft
10. Anything else you want to add that may make performance different Boat has electronic ign conversion kit.
Skidog, dont forget to take your Geritol.
Originally Posted by Upper Michigan Prostar190
On a different note: I like LOTS of snort comin' out of the hole.
Old 08-20-2006, 01:32 PM
TMCNo1 TMCNo1 is offline
Boat: Gone
[quote=PendO]Okay, I would like to compile a list, only because it matters to me and perhaps others. If you would be so kind (inboards only)[quote]
1.RPM/WOT= 4,350
2.MPH/WOT= 43
3. 1989
4. Mastercraft, Prostar 190
5. 351W, 240 hp
6. 1:1
7. OJ 13X13, 4 blade, Polished S/S
8. 93 Octane
9. Mean water level, 725'
10. Electronic Ignition Conversion Kit, AcCELL 8mm Spark Plug wires, Polished UnderWater Gear, Clean and Waxed bottom.
Water temperature definately makes a difference in performance. I always check for performance in the spring in cold/cool water, for comparison purposes from year to year. 2 persons onboard, full tank of gas and gear.
Hope this helps!
Charter Member Number 1
Quote: 2RLAKE,
Old 08-20-2006, 01:38 PM
bret's Avatar
bret bret is offline
1. Max RPM at Wide Open Throttle - 4400-4450
2. Max Speed at Wide Open Throttle - 3 blade 44mph - 4 blade 42.5mph
3. Year of Boat - 1994
4. Manf. & Model - ProStar 190
5. Engine - 350 EFI
7. Prop dimensions (# of blades and pitch) - 3 blade 13x13
8. Octane of fuel - 91
9. Normal operating Elevation - Normal Pool - 461.50
Edlebrock Performer TBI manifold, P&P, ECU modified by Alan Tehan.
Old 08-20-2006, 03:47 PM
kpickett's Avatar
kpickett kpickett is offline
Boat: 1994 Prostar 190 - LT1
1. Max RPM at Wide Open Throttle - 4700
2. Max Speed at Wide Open Throttle - 48 mph
5. Engine - LT-1
7. Prop dimensions (# of blades and pitch) - ACME 475 - 3 Blade - 13x12.5
8. Octane of fuel - 89
9. Normal operating Elevation - 1000 feet
Old 08-20-2006, 04:08 PM
Farmer Ted's Avatar
Farmer Ted Farmer Ted is offline
Boat: 1998 Prostar 190
2. Max Speed at Wide Open Throttle - 43 mph
3. Year of Boat - 1998
5. Engine - LT-1
7. Prop dimensions (# of blades and pitch) - ACME 541 - 3 Blade
9. Normal operating Elevation - 258 feet
The best I could get with the bimini on and the wind was 43, thought about taking the bimini down for about .5 seconds but it's over 100....
Old 08-20-2006, 07:38 PM
TT197's Avatar
TT197 TT197 is offline
Boat: 2011 WTT a 2012,2013
1. Max rpm 4650
2.max Speed 43mph
3. Yearof boat 2006
4. Make and Model Tournament Team 197
5. Engine MCX
6. Transmission 1:26 to 1
7.Prop 13.25x15.75 OJ
8. Fuel 89 octane
9. Normal operating elevation 6000 ft.
Old 08-20-2006, 08:30 PM
6ballsisall's Avatar
Boat: None this week!
1. Max RPM at Wide Open Throttle 4900
2. Max Speed at Wide Open Throttle 50
3. Year of Boat 2003
4. Manf. & Model MC X7
5. Engine MCX 350hp
6. Transmission gear ratio 1:1
7. Prop dimensions (# of blades and pitch) Acme 843 3 Blade 13 x12.5
8. Octane of fuel 89 octane usually, sometimes 91
9. Normal operating Elevation 900
10. Anything else you want to add that may make performance different: nothing
MC's owned:
1986 Skier 19
1995 ProStar 190
2003 X-7
1994 ProStar 205 (current)
