Finally have 100 hours on my 2003 maristar mcx engine. Would like to use mobil one on my next oil change. Anybody out there using it and do you think its worth the price?
There are several discussions under "Technical", "Engine/Drivetrain", concerning viscosity and types of oil, Synthetic vs dino oils. Enjoy!
That said, only you can determine whether the sense of ... whatever ... you get from using Mobil 1 or whatever is worth the cost. It would probably only cost you, what? ... $5 extra per year? The brand of oil filter you buy is far more important to your engine's health than the brand of oil you buy.
'04 MariStar 230VRS/MCX |
After reading what BigMac said, "I" think its worth the $5.00 extra a year.....
Now if we were going to discuss the use of Amsoil, it may be worth an added $5.00 a year more than that.... And Amsoil dealers can usually sell the appropriate "good" "better" or "best" filters too....FWIW
When I got my boat, it had that crappy Pennzoil PZ-3 filter on it. My oil pressure would run about 20 at idle and hit 40-50 at WOT. When my dealer changed the oil at 20 hours, he put a Mercruiser filter on it and the boat then idled at about 30 psi and ran up to about 60 psi at WOT. When I winterized, I put a Wix filter on and now it idles at 40 psi and runs up to 70-80 psi on the gauge. I'm not saying that this is necessarily an indicator of the Wix being a better filter (although "everyone" says it is), but obviously there's a difference in the way these three filters interact with the lubrication system. I have concluded, rightly or wrongly, that it means the Wix is better.
'04 MariStar 230VRS/MCX Last edited by bigmac; 08-19-2006 at 07:47 PM. |
'04 MariStar 230VRS/MCX Last edited by bigmac; 08-19-2006 at 08:25 PM. |
#9
Here we go again. My thought is Synthetic can handle higher temps period. Anyone ever pick up a weed in the strainer? How about a chewed up impellor. As your temp rises and you are worrying about boats, skiers or what have you what would you want in the crankcase? I respect BigMac and his opinion as he definately knows his crap, period! If you feel more comfortable from a history of using synthetics I would go for it. If you have had favorable results with the dino juice follow BM and Indmar's recommendations and change often as it is cheap maintenance. I use synthetic as my ride was delivered with synthetic. I use synthetic in everything including my lawnmower. I still change as often as recommended.
BAREFOOTING: I knew it was gonna hurt when I felt my arse cheeks hit me in the back of my head! ![]() !UOY NAHT RETSAF MA I TUB KNURD EB YAM I
#10
