Old 11-14-2004, 11:13 PM
dchatagnon dchatagnon is offline
Boat: 1993 PS190 285HP Ford 351, Holley 4160
Send a message via AIM to dchatagnon Send a message via MSN to dchatagnon
Rebuild trans Velvet 1:1
Hi,
I have got a 93'prostar 190, the strut bearings are completely dead.
So, I would like to rebuild my transmission.
Does any one has some technical documentations or any tips ?
More over do you know where I can find the parts?
Thanks a lot for the help.
D.
Old 11-14-2004, 11:53 PM
What's wrong with the transmission that it needs to be rebuilt? Try Skidim for parts, possibly manuals.
Old 11-15-2004, 11:52 AM
Thanks for your answer. My transmission is making a noise at slow speed. (850 Rpm)
I think the strut bearings need to be replace. I have no idea how to do that.
Do I need to remove the transmission from the boat? Have you ever done that?
Thanks.
D.
Old 11-15-2004, 12:14 PM
To replace the strut bearings, the propshaft needs to come out, but not the transmission. The bearings need to be removed with a press or slide hammer. There is one at the top and one at the bottom. Installing new ones requires either a press or a large diameter bolt and nut (fine thread, preferably) with washers that won't deform as they pull together. This can definitely be done with the strut still on the boat.
Can you describe the sound? Is it a rattle, whine or clumk?
Old 11-15-2004, 01:11 PM
it's a rattle at low rpm.
Old 11-16-2004, 05:41 AM
Boat: 95 PS 190 EFI
Really, these are strut Bushings, not bearings. But - if you follow JimN's advice, you don't need to remove the strut from the boat to do this procedure. It's not a lot of fun, but I have done it before with the boat on the trailer in an afternoon. It's about a 5-6 beer project (consumption rates vary with mileage)
If one day you're asked:
Will you say:
It's time to SKI.
Old 11-16-2004, 05:42 AM
Boat: 95 PS 190 EFI
is it a thimping rattle, or a clangy rattle? If you grab a hold of the prop (with the motor off of course), can you wiggle the shaft at all from side to side/top to bottom?
Will you say:
It's time to SKI.
Old 11-16-2004, 06:49 AM
André's Avatar
André André is offline
Boat: Prostar 190 1994
Could it be the dampening plate?
Keep skiing!!!
Old 11-16-2004, 08:08 AM
6ballsisall's Avatar
Boat: None this week!
That would be my first recommendation too! Just replaced that, I thought the transmission was the culprit How many hours on the boat?
Old 11-18-2004, 01:05 PM
No I can not wiggle the shaft at all from side to side/top to bottom.
What does the dampening plate look like?
Thanks for all your help.
D.
