Old 08-14-2006, 12:37 PM
6ballsisall's Avatar
Boat: None this week!
Oil Bath hubs?
My boat has oil bath hubs, have never had these before on a personal trailer. What kind of maintenence should I be doing on these? How often to change the oil? How do i do it? What weight oil do I use??
MC's owned:
1986 Skier 19
1995 ProStar 190
2003 X-7
1994 ProStar 205 (current)
Old 08-14-2006, 01:22 PM
P-hat_in_Cincy's Avatar
P-hat_in_Cincy P-hat_in_Cincy is offline
Boat: MasterCraft Prostar 205V "wakeboard edition", 2004
I changed mine out recently b/c I had water in one.
1) Take off wheel
2) Remove plugs (2) in hub housing.
3) Drain
4) Flush
5) Refill
6) Put some sort of sealant on plugs and put them back in
7) Replace wheel
8) TORQUE WHEEL LUGS USING PROPER PROCEDURE!!!
15W40 is what has been communicated to me. Synthetic gear oil has been also...to help with water intrusion.
Old 08-14-2006, 09:34 PM
trickskier's Avatar
trickskier trickskier is offline
Boat: In Search Of...
What did you use as a flush?
The Only Thing That You Can Give and Still Keep Is Your Word
Old 08-14-2006, 10:04 PM
Clean oil.
Old 08-14-2006, 11:32 PM
jmac197's Avatar
jmac197 jmac197 is offline
Boat: 2006 X-7 MCX
How much did you fill it? right to the top so there is no air bubble or do you leave some room for oil expansion?
Thanks
Jim
Jim McCarthy
Delta Lake WaterSki Club
Old 08-14-2006, 11:36 PM
Workin' 4 Toys's Avatar
This is what I think about oil bath hubs, do it as often as you do gear lube in your axle housings in your truck. And use the same lube.....
And JR, did you mean your boat "trailer" has these hubs or your boat...???
Old 08-15-2006, 11:02 AM
Thanks
Jim
I filled it to the approximate level that was in the 'good' hub before I started. Attached is a picture of the 'good' hub before I drained, flushed, and refilled it. I guess it's about 1/8" - 1/4" gap at the top of the sight window.
