#41
I know you could do a Multi ports set up and even swap over to a cam trigger with coil packs running the EDIS-8 coil packs from a ford 4.6L. But doing it cheap is the question. I think the main benefit from TBI would not be the power increase but the reliability, fuel efficiency and bottom end tune ability. Your over all HP will not increase that much if any, but you have to remember when tuning its not overall HP its "area under the curve" that will give you the hole shot surfers, wake boarders, and skiers want.
#42
Just what I was thinking. Wondered what dug up this old,moldy,dead thread. I will give an opinion on this thread subject. I would no more convert carb to FI or vice a versa on any thing I use for pleasure. Too much hassle. If you run into a problem the people that can give you knowledgeable advice could be limited. I see no way that conversion is really cheaper. Having owned and owning several different toys with FI and carbs---each has it's own drawbacks. You see examples of the FI problems on here as much if not more than the carb problems. I have better things to spend my money on-----like more toys.
EPA is not anything I worry about. Lean and rich are what makes me change things. I still would not convert an existing system either way. I would never install a custom system in anything I want to be dependable. Seen this in my hot rod days. Nothing worse than having an engine not run over waiting on a part or converting the whole system because someone went out of business. I like stock off the shelf parts availability.
#45
I am pretty sure GM is not going out of business anytime soon, neither is Ford! That is what this system does. It has a computer that utilizes GM and Ford OEM parts in a single system. These are parts "off the shelf" you just have to have to know what to ask for...
#46
I agree with what JimN is writing. A lot of people will not attempt to fix their cars but they might attempt to fix the boats... |
#47
- Peter TIRE & WHEEL SALES email:tiresplease@gmail.com WEEKEND WHEEL SPECIAL Two 14" Aluminum wheels $195 Two 15" Aluminum wheels $215 Four 14" Aluminum wheels $370 Free Freight within lower 48 Steel and galvanized wheels available. |
#48
1991 Mastercraft maristar 210
Hello help!
I restored my 1991 mastercraft maristar 210, v-8, 5,7 engine I want convert carb to efi system, i dont understand my engine its ford w? small or big block? carb have 4 holes... ( Dealer say ;-) If you are looking for good starting, drive and economy a TBI unit will be fine.* If you are looking for more power you would have to go with an MPFI unit.) Whats options right for my engine? Dealer url: http://www.affordable-fuel-injection...rine-19-1.html options TBI? options MPFI? email: bendrauti@gmail.com |
#49
Your engine is a Ford 5.8L, 351w small block engine with a marine holley 4 barrel carburetor, marinized by Indmar.
IMO a new carburator for $500 and a proper tuning will provide reliability for many years...
James 1989 MasterCraft TriStar 190 SE Last edited by j.mccreight@hotmail.com; 01-15-2013 at 11:21 AM. |
#50
If you are going to junk that carb I could use some extra parts, if it is a 4160. send me a PM if your interested.
