Old 07-28-2006, 02:53 PM
Mikey's Avatar
Mikey Mikey is offline
Boat: Temporarily Boatless
Trailer light problem
OK here is the problem, my brake lights an blinkers work fine until I turn the headlights on. When headlights are on and I hit the blinker or the brakes every damn light on the trailer (right and left side) start blinking. I know very little about electrical wiring and am hoping someone can give me some advice.
Old 07-28-2006, 02:55 PM
sanjuan23's Avatar
sanjuan23 sanjuan23 is offline
Boat: 1992 Prostar 205 w/351 H.O. 4 Blade CNC Acme
Check your ground on your trailer, mine did the same thing but would all of them would come on when I stepped on the brakes but not the break lights.
1992 ProStar 205 351 HO Acme 4 Blade
"The only reason people get lost in thought is because it is unfamiliar territory."
Old 07-28-2006, 03:07 PM
TMCNo1 TMCNo1 is offline
Boat: Gone
It's the ground! Just hooked mine up without the ground and WallAh! Lights will do crazy things, especially when the you have a weak ground. I thought when I changed my trailer tongue over when I installed disc brakes, that I could use the tongue to ball conection as a ground as before and I wound up with a blinking Xmas tree. Ran a dedicated ground from the trailer to the Van and all is well after 9 years.
Run a test ground with a piece of wire stripped on each end from raw metal on the trailer and to raw metal on the tow vehicle and see what happens!
Charter Member Number 1
Quote: 2RLAKE,
Old 07-28-2006, 10:20 PM
Mikey's Avatar
Thanks TMC1 I will give it a try in the A.M.
