Old 07-24-2006, 02:19 PM
BuoyChaser's Avatar
BuoyChaser BuoyChaser is offline
Boat: MasterCraft, Prostar 197, 2005, 350 MCX
2005 197 MasterCraft Trailer Tongue Height from Ground
just picked up a 2006 Jeep Liberty and curious what is the recommended tongue height from the ground so that i can get the right hitch setup on my new liberty...
Old 07-24-2006, 02:31 PM
LakePirate's Avatar
LakePirate LakePirate is offline
Boat: Tristar 190, 1989 / Maristar 210 2002
Send a message via MSN to LakePirate
I think it is around 18 Inches on some of the older trailers, not sure on that one.
It's Snowing in the UP
Old 07-24-2006, 02:37 PM
erkoehler's Avatar
18-20 inches
www.boathouseh2o.com
Old 07-24-2006, 02:55 PM
Ric's Avatar
Ric Ric is offline
Boat: 2005 Prostar 197 / MCX
anxious to hear how that bad boy acts with a prostar hitched to it.
What tongue weight is suggested?
Originally Posted by TX.X-30 fan
Say yes to cheap beer---- no to ethanol.
Old 07-26-2006, 12:11 PM
BuoyChaser's Avatar
Originally Posted by erkoehler
18-20 inches
so any range between 18-20" but which one is ideal to have perfectly level 19"???
on measuring the Jeep Liberty CRD from the ground to bottom of receiver is 13-1/2" (16-1/2" to top)...so that means I'm trying to get the right "Ball Mount"...
unfortunately i need to order today and i didn't measure my MC trailer last night, arghhh...anyone have close access to their 2005 197 or X7 trailer to tell me the following:
Step 2 - Level trailer, then measure from the ground to the top of the trailer coupler.
here's a link to how to measure: Level trailer, then measure from the ground to the top of the trailer coupler: http://www.reeseprod.com/menu/produc...=Ball%20Mounts
Old 07-26-2006, 12:43 PM
BuoyChaser's Avatar
Mopar Class II Hitch Receiver has a 2-inch opening and can handle loads of up to 5,000lbs. Features custom designed brackets for easy wiring harness mounting. Hitch Receiver Plug with Jeep logo included. Ball Mount and Hitch Balls sold seaparately.
Engine 2.8L Turbo CRD I-4 5-speed automatic transmission - Max. Loaded Trailer Weight 5,000lb
Engine 3.7L V6 6-speed manual transmission - Max. Loaded Trailer Weight 3,500lb
Engine 3.7L V6 4-speed automatic transmission - Max. Loaded Trailer Weight 5,000lb
Base Curb Weight - 4,296lbs
Payload Capacity - 1,150lbs
Maximum Gross Vehicle Weight Rating - 5,650lbs
Class III Towing - Maximum Gross Combined Weight Rating 4WD 10,150lb (
- Maximum Loaded Trailer Weight
Tongue Load Limit 750lbs
Trailer Tow Group - Class III Reciever Hitch, wiring harness, adapter and heavy-duty engine cooling with auxilary oil cooler for automatic transmission
Old 07-26-2006, 12:56 PM
Ric's Avatar
Ric Ric is offline
By Gawd this may work!
Old 07-26-2006, 12:57 PM
BuoyChaser's Avatar
but hold on there is a note:
RESTRICTION: Trailer frontal area limitation of 64 square feet with 5,000-lb trailer; maximum trailer length of 25 feet; trailer sway control recommended.
so this actually isn't too bad...i have a horse trailer to pull that is 7'4" Tall x 5'11" High so that is 88"x71" and 43.38sq ft...horse trailers are pretty big so certainly means you can tow a pretty big BOX!!!
Old 07-26-2006, 12:58 PM
Ric's Avatar
Ric Ric is offline
Get yo butt out there and tow it
BuoyChaser's Avatar
just need to get the right size ball mount now...
