  #201
Old 04-30-2015, 04:53 PM
gonordiquesgo gonordiquesgo is offline
Boat: x25 2012 6.0
Quick question. I have a 2012 X25 6.0 I will add ballast next week. The setup I choose is to put 600 lbs in the rear locker and plug each of them to a new pump and independent switch on the dash board as recommended by numbers of you here.
Can I like the 600 rear locker with a 750lbs on the port side and expect it to work properly when I fill and when I flush ?
Thanks !
Old 05-11-2015, 02:12 PM
TheWoons TheWoons is offline
Boat: 2014 X30. If you want a custom Soulcraft let me know :)
You can fill the rear locker, fill the 750 under the port coffin seat, fill the stock ballast on the port side and the center and you should be good to go. You can also add another 400lbs in lead up and down the port side if you really want it to surf well
2014 X30
