Old 05-25-2018, 10:26 AM
Jorski Jorski is offline
Boat: 1993 190 with LT1
1993 Prostar carpet
Anyone know what weight the OEM carpet was in 1993 190 Prostar?
Time for some new carpet.
Old 05-28-2018, 07:43 AM
The OEM I had before replacing was 20 ounce short cut pile carpet.
I used the same 20 ounce weight in cut pile (I am not big on Berber) in the 93 that is in the garage.
There are a million and one carpet sources but I use these folks for several reasons. I also like their glue.
John 3:16-18
Old 05-29-2018, 05:50 PM
That looks great! Do you remember which gray you used?
Old 05-29-2018, 06:27 PM
The gray in the 93 is light gray.
Here is the midnight I put in other boats along the way.
They are close in color, in particular in different light from time to time. Either one looks good.
If you are doing this yourself, make sure you cut and lay in the same direction of sweep for all pieces. When you clean it or run your hand across it, it should all sweep in the same direction. You can tell a difference in the direction of the sweep if not all the same.
John 3:16-18
