Old 02-10-2015, 10:12 PM
Jayhawk's Avatar
Jayhawk Jayhawk is offline
Boat: 2001 X-Star
X1 ski locker bag
I keep patching the ski locker bag in my '01 xstar, but it's a losing battle. Anyone have pics of their X1 bag/fittings? I want to compare it to what I have now. Would it still be available from MC or dealers? Any idea on cost?
We fill the bag every time we go out. Any issue forgoing the bag and throwing 300-350 lbs. of lead in there and leaving it?
Old 02-10-2015, 10:16 PM
MC25's Avatar
MC25 MC25 is online now
Boat: 2016 X30, 85 S&S
from what ive seen these bags are like unicorns. i think they pop up on ebay from time to time!
-Aric
2016 X30-Wetsounds galore
2017 Misty Harbor Tri-Toon
Old 02-10-2015, 10:34 PM
AlbertaSurfer's Avatar
AlbertaSurfer AlbertaSurfer is offline
Boat: 2008 Outback DD
$170 gets you a 800lb bag for the locker from Straightline. 18"x18"x65"
Put some quick release fittings on it and you can pull it for easy cleaning, cause that locker gets durrrty!
Old 02-10-2015, 11:43 PM
TravisQ TravisQ is offline
Boat: 2009 X-star
This bag works pretty well and all the ports are at the right end. . Get a bit creative with the fitting, a few 90 degrees, some 3/4" hose, and some clamps. it's fills the locker well. Short in length by 8 or so inches.
http://www.wakemakers.com/fly-high-tube-sac.html
Otherwise you can contact high fly and they can make you a one off ballast be based on the old one.
I have a 2001 xstar. Had the same problem.
Old 02-11-2015, 12:35 AM
VP46's Avatar
VP46 VP46 is offline
How did you fit an 800lb bag in the ski locker? Is the bag made of tungsten? ;0)
Assume you cant fill it all the way? I can only fit about 300lbs of water in mine!
Old 02-11-2015, 12:42 AM
VP46's Avatar
Like you I had to replace the original bag but I did this 2 yrs ago. Wakemakers happened to have one of the VERY LAST purpose built 205v ski locker bags left.
I'd call them and do as TravisQ suggests... have one made.
Old 02-11-2015, 12:54 AM
swatguy's Avatar
swatguy swatguy is offline
Boat: Nautique
The tube sac leaves a little to be desired. It's less weight than factory and due to the fact the ports are on the top when it fills it will push you're locker door open. It's annoying. A custom 10X10x80 bag fits perfectly. Fly high has the specs and you can get the 3 ports put on the end to match your current design. Anything out if an X1 will have different port locations.
A custom bag from fly high is around 350-400and that's about what your dealer would charge for s factory bag.
I wouldn't recommed putting steel or led in the locker. No matter what you do it will get water in there somehow. Also you want the weight stretching through as far forward as possible . The lead bags will slide around every time you get out of the hole. Since you're thinking of just filling it and leaving it full the tube sac should do the trick because the ports won't be in the way then.
CURRENT: 2008 SANTE 210
2000 Mastercraft Xstar
2003, Ski Centurion Cyclone
88 2001 Nautique
Old 02-11-2015, 08:16 AM
BudmanV24 BudmanV24 is offline
Boat: 2006 MasterCraft XStar
Let me make a phone call today. I think I have a source for oem X1 kgb bags that's far less than $400. I'll let you know what I find out.
2006 MasterCraft X1 - Sold
2003 Sevylor Caravelle 7' 6"
Old 02-11-2015, 11:49 AM
Jayhawk's Avatar
Boat: 2001 X-Star
Thanks for the feedback on the bags, guys. And appreciate the feedback on the lead, swatguy. It didn't sound like a very good idea, but I'm tired of dealing with a leaking bag, so thought I'd throw it out there.
Please let me know what you find, Bud.
Old 02-11-2015, 11:59 AM
swatguy's Avatar
Boat: Nautique
If you just manually fill that tube sac and then cap it it will fit perfectly. It just won't wiork very well with all the hoses attached to the top.
88 2001 Nautique
