  #31
Old 05-13-2013, 09:51 AM
Shawnymac11 Shawnymac11 is offline
Boat: 1992 Mastercraft Prostar 190
Interesting. The mixture screws only affect the idle circuit and have no impact once you get into the throttle a bit. Have you verified that the firing order is correct? It isn't too tough to cross two wires and spend a bunch of time pulling your hair out trying to figure out what's going on.
Definitely didn't change the previous setup. I did one wire at a time and marked the wire and cap. Could only be wrong if it was previously wrong.
Old 05-13-2013, 10:33 AM
Sounds like it is probably time to deal with the carb.
Peter
Tandem Axle Trailer Special $699
Includes: 4 T07 wheels, 4 ST205/75R14 Kenda
Loadstar KR03 Radial tires, mount and balance
Free Delivery
ALUMINUM WHEEL AND TIRE PACKAGES
SINGLE AXLE 14" PACKAGE STARTING AT $369
SINGLE AXLE 15" PACKAGE STARTING AT $439
TANDEM AXLE 14" PACKAGE STARTING AT $649
LED lights, Spare Tire Carriers, Chrome & Powder Coated Lug Nuts
GOLF CART TIRES & WHEELS
PM me or email tiresplease@gmail.com
Old 05-13-2013, 10:38 AM
Are you avoiding the holley 4150 question? Haha
Old 05-13-2013, 10:42 AM
Not avoiding it, just don't have any experience with it. My experience with marine carbs has been with the 4160.
Peter
Free Delivery
Old 05-13-2013, 10:54 AM
Okay thanks.
Old 05-13-2013, 01:23 PM
I wouldn't expect any problems with a carb other than a 4160. Resale could be the only issue. Holley carbs are easily tune-able.
Peter
Free Delivery
Old 05-13-2013, 03:07 PM
I'm not sure I understand what you are saying.
Old 05-13-2013, 03:17 PM
You had mentioned switching to a Holley 4150 carb. I would suggest the 4160 as this is the standard carb for MC.
Peter
Free Delivery
Old 05-17-2013, 04:01 PM
Trying to test the fuel pump now to make sure it's working properly. Does anyone know the capacity or measuremt I can take to verify its pumping the proper amount?
Old 05-17-2013, 04:13 PM
IIRC, mechanical fuel pumps are good for about 7psi and the flow rate is fairly low, too. Doesn't need to be high pressure or flow, since the accelerator pump is fed by the bowl and the incoming flow is controlled by the float. However, if you haven't checked the float for bouancy, do that- they often develop tiny holes and if this happens, it's no longer a 'float'.
