Old 07-03-2018, 08:44 AM
4stauffers 4stauffers is offline
2014 X25 -- Runs on land, not in water
I have a 2014 X25 with 6.2 OPS -- Engine starts and runs great out of the water. When you put it in the water it starts, rough idle then pops through the intake. We put a new fuel pump in -- fired right up and ran great for 5 min then died. Ilmor said cats/manifold must be clogged and boat can't handle the back pressure -- Installed new manifolds and it does the exact same thing. They then found a dirty injector -- we replaced all the injectors and it does the same thing. No codes. Any thoughts?
Old 07-04-2018, 01:16 AM
Boat: 86 Magnum Skier
Was it these engines that had the problems with the distributor and you had to move it one tooth and then retime it?
back pressure, ecm, fuel pump, stalls, x25
