Old 06-09-2016, 01:04 PM
dhanni848's Avatar
dhanni848 dhanni848 is offline
Boat: 1988 Mastercraft TriStar 220
Impeller, drive belt (learned the hard way this Sunday), any common fuses, volt meter, electrical tape.
Old 06-09-2016, 02:33 PM
Dylan's Avatar
Dylan Dylan is offline
Boat: Yamaha 212
I also carry a little breathalyzer too.
I wouldn't put too much trust in one of those... I was playing around with one while out with friends and it was all over the place.
As far as the initial question goes, preventative maintenance. The gear you have is good. I will not be diagnosing a spark plug issue while on the water.
Old 06-09-2016, 02:38 PM
FoggyNogginz's Avatar
FoggyNogginz FoggyNogginz is offline
Boat: 2017 X10
Location: Center Hill Lake, Old Hickory, and Norris Lakes in TN
+1 Impeller...I've changed two on the water now
Old 06-09-2016, 02:42 PM
Wicker68's Avatar
Wicker68 Wicker68 is offline
Boat: '09 CSX220 SS
Originally Posted by kjohnson View Post
Dead in the water from a damn bad kill switch.
Been there. I cut my kill switch wires and put male and female ends underneath so if it goes again I just unplug it and hot wire it until I can get a new kill switch.
Old 06-09-2016, 05:34 PM
agua4fun's Avatar
agua4fun agua4fun is offline
Boat: Prostar 190 Sammy Duvall & 230VRS
For Me:
Small & Large Hose Clamp
Impeller (Its an old one from my annual replacement)
Main Belt (and Wrench to loosen belt) (Again its an old one from a replacement)
Bilge Pump (maybe over the top)
Bulb for my incandescent anchor light (I use my boat in the dark often)
All of the usual tools: screwdrivers, wrenches, electrical tape, zip ties, flashlight
Fuel line remover tool (left over from my pump going out)
Knock sensor (for some reason i go through these every 3 years or so)
Extra key hidden somewhere (took half a day of vacation to drive to the nearest dealer to get a replacement)
fuel pump, run out of gas, spare parts
