  #31
Old 09-08-2014, 02:22 PM
h_2_o h_2_o is offline
Boat: 89 Prostar 190
OK found out a bit more info today and not good news on my end. seems that the strut has been replaced which probably explains why the piece that is broken is the way it is. Anyway I'm going to pull it to make sure there is no real glass damage under there if there is fix it and 4200 it. In doing this does anyone have a procedure on how to properly align the strut so it is inline with the center of the boat. At this point I do not want to cut out the log as it might be in the proper place currently and the strut may be misaligned.
any help would be appreciated. thanks again
Old 10-01-2014, 12:45 AM
oh my oh my if there is a cover on the pylon kids check it out. So the corrosion had it so ballooned up that there was no way to pull it out. So I ended up having to unscrew the floor up around it. lift it up slightly, put a sawzall in between the floor and cross-member and cut it out. yes that is al dust in the second picture there.
and now some pictures of the corrosion and the dumb pylon embedded into the cross-member along with a few pictures showing how bad the pylon was
finally drilled a few holes on the bottom part of the pylon, got one side to slightly crush put a lot of heat on it and it finally came out. that was a pain.
then in the back end of the boat i had to remove the prop shaft so that i can get to the cutlass bearings and replace them. here it is seperated
Old 10-28-2014, 04:31 AM
so went to change the cutlass bearings as described here http://www.pbase.com/mainecruising/replacing_a_cutlass and it did not go as nicely as they show. any ideas if i have the bearings cut through and all the screw did was pop out a small round piece in there. now i have it cut in several places and and not doing very well with it. any help is appreciated.
Old 10-29-2014, 08:40 AM
d2jp's Avatar
d2jp d2jp is offline
Boat: ProStar 190, 1989, 351W
I changed mine two years ago. I'd recommend spraying w/ PB Blaster and let it soak for a couple of days. At least, and keep adding PB if it's drying out. The pieces should come out with some light tapping using a hammer and wooden dowel.
Jack
1989 ProStar 190 Power Slot
Somewhere between SML and LKG
Old 10-30-2014, 01:25 PM
SeanFTristar190 SeanFTristar190 is offline
Boat: Mastercraft Tristar 190 1989 351 Indmar
I agree with Waterlogged 882. Use resin and fiberglass mat, its stronger. Make sure you saturate the mat well with resin, it will make it stronger. Do not use too much hardener as if it sets up to fast, I find is get a bit brittle.
Hope this helps
Old 11-22-2014, 06:41 PM
Wingnut Wingnut is offline
Boat: 1998 M/C 205, 5.7 TBI
H2O- Was this boat a salt water boat?? the corrosion on the pylon and other areas you have shown look suspiciously like salt water. I had a similar issue with the 205 I finished- Had to hunt all over but found replacement plates in a parts room in alabama. Additionally I think youve already fixed the shaft log but the aluminum one you had in the boat stopped being manufactured and MC went to a replacement composite shaft log. Ill send a picture.
Old 11-22-2014, 06:43 PM
This is the replacement shaft log I ordered thru MC - $17.50
Old 11-22-2014, 11:08 PM
tph's Avatar
tph tph is offline
Shaft log
I think the '89 needs a log that looks like this:
Old 11-23-2014, 12:41 AM
d2jp's Avatar
This will not work in an 89 PS
^^This is the correct part^^
Jack
Old 02-02-2015, 04:55 AM
sorry guys havn't looked at the thread in a while because of winter down time but some answers.
no saltware, midwest boat have the info on all the owners, michigan to ohio to indiana.
as for the shaft log, i'm actually replacing the cutlass bearing first because it is warn funny and going to see how far off the shaft is once it gets replaced. if it mostly centers the shaft up i'll be happy and not worry about pulling the old one and glassing a new one in. I've been doing a fair amoung of glass work over the past 2 years so I am fairly comfortable with that.
now a silly question, i was looking at the underside before winter storage and the front fin looked a bit off. for some reason it has been removed. Anyway I pulled it off, they did a horrible job of bedding it and i mean horrible. I can do the bedding just fine but anyone have any pointers on re-aligning it so it is correctly aligned?
also the guys over at OJ are freaking awesome. I am turning my own pylon and was looking for what type of nylon/plastic/whatever is used on current mc for that little piece where the rope goes. they sent over a chunk of vesconite to use for me so this should get fun soon.
