Old 07-20-2016, 01:33 PM
Lbferguson Lbferguson is offline
Boat: 1995 ProStar 190
Engine Cover
Panic when opened engine cover - wheewww wasn't animals eating it foam had gone to heck and back. thread I was reading was 2005 so reposting pics Takes 8 feet
1. Trying to remove cover from hing to inside and very hard with nuts and screw outside.
Didn't want to remove floor screws not knowing how many times they can come in and out. Any suggestions We had put carpet and had it out couple times but don't remember what is inside.
2 Seen on a thread some use foam to reline and some use the aluminum fronted . Found site people referred to McMaster - Carr
- Plain-back sheeting has a temperature range of -40 to 225 F. Meets UL 94HBF for flame retardance. Water-resistant sheeting has a urethane coating that also protects against oil.
IS THERE NEED FOR FOIL ? local & can pick up My foam has been there 21 years ?
Thanks
Old 07-20-2016, 01:38 PM
plug holes with epoxy if getting loose - the foil is just cool looking..
pop out the cup holders and it will give you access to the screws.. if you don't have huge forearms
Old 07-20-2016, 01:55 PM
d2jp's Avatar
d2jp d2jp is offline
Boat: 1992 PS 205-351w,285HO
Bedliner is also an option. DIY or professional. My foam is missing, so I'm looking at replacement options, and considering the foam didn't last 20 years I'm not sure how long the adhesive used for the foil faced or sheet foam will last.
And I'm really wondering if it's worth the trouble - how much quieter are you going to make a big V-8 engine sitting in the middle of the boat?
Jack
1992 ProSport 205
Smith Mountain Lake, VA
Old 07-20-2016, 03:32 PM
Engine Cover Link
I've done alot of searching & reading especially on this site. Found this link from early 2003 I believe Pictures I posted were approx on page 8,
Through the posts found McMaster-Carr is located about 15 minutes away, called it's public but has tons of product. Went back narrowed it down. Choice is Black Water resistant coated for oil, gas and withstands heat in Black Foam or the foil lined which people choose to use the silver DUCT as in venting tape to finish off. They claim it makes quiet and cool.
Once my son decides I will keep you updated patterns are on thread I just shared new because it was older wasn't sure I'd get reply. I have the skinny arms, first called for oil filter, husband and son couldn't get under neath. Now I'm supervisor getting old LOL
Here's link : http://www.mastercraft.com/teamtalk/...ght=insulation
Here is the plain foam takes 8 feet they say http://www.mcmaster.com/#5692t14/=13cr0c2
If I find out I'm wrong on choice after re reading I will edit this post
Scroll down to the foil faced. The people claimed used the self adhesive after cleaning real good : Stay tuned we're going to try. Link http://www.mcmaster.com/#sound-contr...lation/=9dzrvc
1995 prostar, engine cover, interior
