Old 06-09-2017, 04:24 PM
Eckie's Avatar
Eckie Eckie is offline
Boat: 2007 XStar
Originally Posted by MLA View Post
Clarion wired remotes use their own proprietary plugs. The AUX are audio only, no data. You may have a remote 3.5MM jack thats plugged into one of the two AUX inputs, you will just need to decide which one to drop off to make room for the BT.
^^^ THIS ^^^
Old 07-23-2017, 07:19 PM
JP-OH's Avatar
JP-OH JP-OH is offline
Boat: 2012 x-15 5.7
I crawled under to have a look at my wiring and the cmd6 head unit has 2 yellow wires both with fuses. They merge together just before a large connector. If i want constant power which/where should i tap?
50.241899, -115.857747
Old 07-23-2017, 07:51 PM
MLA MLA is online now
Boat: pontoon
The boat may have two yellow wires, but I dont recall the CMD6 harness having two. Yellow is constant on the CMD harness. A volt meter will confirm.
Old 07-23-2017, 08:55 PM
JP-OH's Avatar
Boat: 2012 x-15 5.7
Here is a pic. One of them is a slightly larger gauge than the other and they both come from the head unit. Also pictured is where they merge.
Old 07-23-2017, 09:25 PM
Boat: pontoon
None of that is the actual head unit harness but rather the boat side. Go right to the back of the head unit for the actual head unit harness colors.
Old 07-23-2017, 09:44 PM
JP-OH's Avatar
Boat: 2012 x-15 5.7
I must confess to not having much expertise in stereo witing but these wires look like the are originating at the heah unit.
Old 07-23-2017, 10:22 PM
Boat: pontoon
http://www.clarion.com/us/en/pdf/CMD6_Inst.pdf
Old 07-23-2017, 10:40 PM
JP-OH's Avatar
Boat: 2012 x-15 5.7
Yeah. I have that. Hence my confusion at the 2 yellow wires that come out of the head unit, both of which are fused and that merge together before the connector.
Old 07-23-2017, 10:57 PM
Boat: pontoon
Rather than wire color, look at it from a terminal pin out number. Cant speaker for what mastercraft has done, but clarion only used one yellow MEM/B+ for that head unit. Again, a volt meter will confirm.
Old 07-24-2017, 09:23 AM
Truekaotik Truekaotik is offline
Boat: Not a mastercraft
You can tag either one in the mastercraft boat side of fuse.
audio, bluetooth, clarion, cmd6, mbt-rx
