  #121
Old 02-09-2009, 08:40 PM
JimN JimN is online now
Talking
Originally Posted by TX.X-30 fan View Post
Is this thing on???????
Do you have me on ignore????
Its in the engine spec part of the owners manual, and my 04said 70!!!!
"Me, me, me- it's all about me!" Stuart.
Lighten up, Francis. I started to post and couldn't finish until after you had added yours, so I didn't know about your info.
Old 02-09-2009, 08:42 PM
I think they came with 8 ga, so I would probably go to 6 ga. Yeah, it can be a PITA but it avoids problems.
Old 02-09-2009, 08:47 PM
brucemac's Avatar
brucemac brucemac is offline
jim you don't think i'll have issues with the 70 amp alternator do you? i'm not the guy that goes around blasting his stereo all day, but i would like to feel confident that i can listen to it at reasonable to loud volumes a couple times a year on houseboat trips and such without ruining my alternator, or hanging out and listening, starting, cruising, listening, etc.
the larger 1000W amp is supposed to be super efficient, class G/H
íViva 205v!
2003 X-2 MCX
Old 02-09-2009, 08:59 PM
Talking
"i'm not the guy that goes around blasting his stereo all day, but i would like to feel confident that i can listen to it at reasonable to loud volumes a couple times a year on houseboat trips and such without ruining my alternator, or hanging out and listening, starting, cruising, listening, etc."
"it will be 1000W RMS on one amp ([email protected] and [email protected]) and ~400W RMS ([email protected]) on the 2nd. i'll never see that kind of output though. the smaller amp is a class AB and the larger one is a Class G/H amp with regulated power supplies and fans."
If I hear your stereo up here, I will publicly post it here.
Measure the voltage drop at the battery when you start the motor and turn all of the accessories on. If it drops more than a few volts, adding current draw will only make it worse. At higher RPM, it does produce more voltage and current but you need to deal with the draw at idle in order to not cause it to drop too low.
What is the total of the fuse values on the amps?
Old 02-09-2009, 09:01 PM
07Pro-V
Posts: n/a
how about if u are using a battery isolator do the batteries still need me be the same then or is it ok to use different ones?
Old 02-09-2009, 09:05 PM
brucemac's Avatar
the larger G/H has (4) 30 amp and the smaller AB amp has (1) 30 or 40 amp, i'd have to look again, it's not on their specs.
íViva 205v!
2003 X-2 MCX
Old 02-09-2009, 09:12 PM
TX.X-30 fan TX.X-30 fan is offline
Boat: mastercraft, X-30, 2004, MCX.
Could you see my bloomers under that tennis shirt??
___________________________________________
Myself I'll live on the edge and surf without a helmet.
Old 02-09-2009, 09:17 PM
So, at 1/2 of worst case current draw, they could draw 50A-70A by themselves. If you're running at idle, your fuel pump, ECM, ignition system, lights and any other accessories could be drawing 25A-40A. The math doesn't make it look good for a 70A alternator. The batteries will fill in as a reserve tank but once they need to be recharged, it adds to the load.
Old 02-09-2009, 09:18 PM
I wondered what the pink reflection was when I looked at the sky.
Old 02-09-2009, 10:00 PM
If they're not in the same condition, one will always be an additional load.
amp, ballast, batteries, stereo, system
