Old 11-22-2017, 12:43 AM
rs52257's Avatar
rs52257 rs52257 is offline
Boat: 2015 X-23
X23 7.4L Prop Shaft
Has anyone had prop shaft problems on a 7.4L? Mine busted near the V-drive and prop shaft shot out the bottom of the boat, never to be seen again. Got lucky that boat didn't not sink, it was taking water in extremely fast. Attached is a pic of the broken shaft. Boat has 139 hours on it. Is this a power problem? A misalignment from when they did the 100 hour service? I am running a 1000lbs of steel shot, the 3000lbs of factory ballast and at times will have 10-12 people in the boat as well, so I am well over 5000lbs of ballast at times, boat has plenty of power, but wondering if it is just to hard on that drive shaft? Ideas?
Old 11-22-2017, 01:02 AM
MC25's Avatar
MC25 MC25 is online now
Boat: 2016 X30, 85 S&S
First one I’ve seen
-Aric
LONE STAR MASTERBASH 2018
Details released eventually
2016 X30-Wetsounds galore
2017 Misty Harbor Tri-Toon
1985 S&S- For Sale
Old 11-22-2017, 06:54 AM
Fullpass's Avatar
Fullpass Fullpass is offline
If I was an Engineer at MC, I would gladly take that coupler back, and have it looked at, check the Rockwell hardness of the shaft, make sure its not a supplier issue, not then design issue, maybe a larger diameter shaft is needed, less pitch prop. Give you a new replacement shaft & prop. See if it happens again...hope it doesn't. If it does then some limits need to be stated on the ballast loading. Like you say, got lucky you didn't sink. But if I was you, maybe just a 1000lbs less of ballast, for your own sake, your the captain.
Old 11-22-2017, 07:18 AM
moosehead's Avatar
moosehead moosehead is online now
Just snapped while underway? Surfing? No debris or running aground or unusual vibrations?
How did you get her back to shore? .Glad you were able to do so.
Old 11-22-2017, 08:47 AM
gsxrjtt's Avatar
gsxrjtt gsxrjtt is offline
Boat: changes every month
Id have engine alignment checked again
Old 11-22-2017, 09:07 AM
Mastercraftdave's Avatar
Boat: 2015 X23 SS 6.2L
I had my shaft snap on mine this year and it was a misalignment issue. I didn't lose the shaft or the prop. It was almost as if the engine settled on the mounts a bit cause it was off a few degrees.
Dealer had me back up and running for the next weekend.
Old 11-22-2017, 10:02 AM
jjsaustin jjsaustin is offline
Boat: 2015 x30
The Nautique G's had a big issue with shafts snapping with 100 or so hours on them. Two of my 4 neighbors with G's had this happen to them.
https://www.planetnautique.com/vb5/f...-issues/page14
If you are expecting warranty to cover this, I'm not sure I would be posting that you clearly overweighted the boat, which may give them an excuse to deny the claim.
Old 11-22-2017, 10:22 AM
rs52257's Avatar
Boat: 2015 X-23
Yes it snapped going out about 25mph heading back to dock to get my wife. That's where I was lucky it had enough rpms and just shot out the boat. We didn't hit anything. Had a buddy on the water with me and he rushed over. Used his 8.3 pump inside the engine compartment while he towed me in. We were only about half a mile from the dock. Got it on the trailer and it drained water for 5 minutes. Was pretty scary.
No vibrations or anything. Engine just started free revving I threw it in neutral and the boat came to a stop.
Sent from my SM-G920V using Tapatalk
Old 11-22-2017, 10:24 AM
rs52257's Avatar
Boat: 2015 X-23
I had to fight with them but they warrantied it in August. My concern is if it does it again. They wanted to try and say I hit something but the strut and rudder had no damage to them
Old 11-22-2017, 10:29 AM
rs52257's Avatar
Boat: 2015 X-23
Interesting Dave. What was weird to me is that coupler in the picture is how it came out of the boat and 1 of the nuts holding the coupler was different. Almost like someone was adjusting alignment and dropped a nut below the fuel tank and threw on a different one. I find it hard to believe that the factory would use a different nut on something that is a rotational mass. I am the second owner. I think dealership screwed something up on the 100 hour service before I bought it
