  #31
Old 02-07-2018, 06:59 PM
Originally Posted by mertens777 View Post
This is NOT for speed itís for power to get on plane when fully loaded lol. I know itís not a speed boat!!!!!!!
Item description says for imdmar 5.7. Claims itís been tested.
Ask if it includes an IAT (Intake Air Temp sensor)- if it does, it may do the trick but honestly, if you're adding more than 1000lb of water and a few people, it's probably going to be tough to find the right combo unless you can have a bunch of props to test, too.
Old 02-07-2018, 07:10 PM
mertens777 mertens777 is offline
Boat: 1989 Maristar 240, 2005 Mastercraft Xstar, 2018 NXT 22
It does include air temperature sensor
Thanks
Old 02-07-2018, 10:12 PM
1redTA's Avatar
1redTA 1redTA is offline
with the IAT “sensing” cooler air, the ECM will add extra timing since an engine is less likely to experience pre ignition in cooler air
1981 MasterCraft
19' Skier 351W PowerSlot
Old 02-08-2018, 08:22 AM
Keith2230's Avatar
Keith2230 Keith2230 is offline
Boat: 2006 X-30 MCX
Have you tried the ACME 1285 14.5x14? I can run almost 3k lbs of ballast/people and it gets on plane with little issue. Since I switched I don't even bother with the GSA launch mode. IMO it's the all around best prop for the MCX for surfing and wakeboarding with lots of ballast. My boat is a bit smaller and maybe you're running more ballast so your mileage may vary.
That said no one on this forum would shun more power. If you've got the money to upgrade to a star with a 6.0 - 8.1 that will certainly get it done.
Old 02-08-2018, 08:43 AM
Running full ballast and added PWT bags, the 5.7 struggles a lot. I worked with Acme and we have the prop maxed out and she still struggles. I know why they offer a larger motor as an option in this boat. I’ll get a star with the bigger motor next time
I'd give Eric at OJ Props a call and see what he can do for you.
Johnson Propeller Co., Inc
750 Natalie Blvd
Loudon, TN 37774
Phone: 865-458-5205
Fax: 865-458-0686
Toll-Free: 800-359-9730
Also to note: The Indmar Magnum is NOT the same as the MCX so that tuner isn't even for you engine.
Tim
Old 02-08-2018, 08:53 AM
Yeah, thanks. This tuner can be used by multiple engines. This tuner does only a basic function, it does not allow you to change multiple limiters (which is good, wouldnít want to) like some that are designed for specific engines
