Old 01-18-2018, 11:32 PM
Bernie123 Bernie123 is offline
Boat: 84 MasterCraft. 351W
Replace engine
Restoring a 1984 Pro star, With a 351W, The engine block looks good, needs heads, does anybody have any suggestions New or Up grade the heads or is there a newer engine.
Old 01-19-2018, 05:48 AM
waterlogged882 waterlogged882 is online now
These folks will build a set of GT40P heads to spec. They come ready plug-and-play. All you'll need is a marine gasket kit.
==> https://www.flotekheads.com/tri-state-cylinder-head/ <==
A friend of mine has used them previously and was completely satisfied with service and product. Took them about two weeks to build the set. Be sure and request that the mounting bolt holes be drilled to 1/2" diameter to fit your 351.
$0.02
John 3:16-18
Old 01-19-2018, 01:06 PM
Thanks Ill check it out
Old 01-20-2018, 01:49 AM
david_ski david_ski is offline
Boat: 2003 SN196, PCM 330HP 5.7L, ZeroOff
I used Tri-State to get me a set of GT40 heads back in 2008 for my 351. They did a great job for me and highly recommended
Previous: 1993 ProStar 351HO
Old 01-20-2018, 09:08 PM
Do you have to get different manifolds?
Old 01-20-2018, 09:18 PM
No.
However new exhaust manifolds are a good thing to replace and forget about them for a long time, but that is not required. Use your own judgement for that.
The GT40P heads are for the 302CI but are identical in specs for the 351; thus the need to have the bolt holes enlarged to 1/2" diameter, to mount to the 351CI. Merely a little larger bolt for the 351.
A marine application gasket set is important.
John 3:16-18
Old 01-21-2018, 11:58 PM
MDB1056 MDB1056 is offline
Boat: 1983 Starts & Stripes Powerslot, 92 Hydrodyne Comp
Rebuild what you have as insures will bolt together just fine. You can get all sorts of rebuild upgrades on the heads and entire block & components . No need for a different engine . EZti remove and install.you can easily crank out an additional 30-50 hp
Old 01-23-2018, 07:01 PM
Thank you so much for your input.
Old 01-27-2018, 02:06 PM
I have another question or hundreds! Where can I buy motor mounts for an 84 Mastercraft and exhaust headers?
Old 01-27-2018, 03:53 PM
Discount Inboard Marine have both exhausts and motor mounts.
