  #231
Old 08-27-2010, 08:41 AM
DooSPX's Avatar
DooSPX DooSPX is offline
WOW! Beautiful 85 Skiier!
A.K.A. One of a kind mistake
2011 Best In Show- 1987-2000 class
Trying to keep slalom alive
Need a new prop to fit your needs? Call Eric from OJ PROPS 800-359-9730
Old 09-03-2010, 01:23 AM
jipster43's Avatar
jipster43 jipster43 is offline
Boat: '93 Stars & Stripes
Here's a before and after of my teak. I couldn't find ANY sandpaper in the 400 grit and had to use a 3M product that was kind of like a very thin sponge. It was supposed to be 400 grit, but the 600 grit did way more to clean up things. I think it would have turned out a lot better if I could have used the proper product during the 400 grit stage. The last three stages of sanding were done with steel wool - again I couldn't find any 1000 grit, 1200 grit sandpaper in Bozeman.
JP
Old 09-03-2010, 01:24 AM
jipster43's Avatar
JP
Old 09-03-2010, 01:26 AM
jipster43's Avatar
Here it is on the boat!
JP
Old 09-03-2010, 01:44 AM
Bert's Avatar
Bert Bert is offline
Boat: Prostar 190 and X2
Originally Posted by americanskierJim View Post
I used this to do mine with. It is for marine teak and only $10.00 a pint at HD.
Best stuff. What I use.
Old 09-03-2010, 11:54 AM
DooSPX's Avatar
I use the Watco too. Its good stuff
Old 09-16-2010, 05:36 AM
ProStar190 Downunder ProStar190 Downunder is offline
Boat: Mastercraft ProStar 190, 1993
Hi guys,
First post after very recently becoming a Mastercraft owner - 1993 PS 190 - and have decided the first task is to restore the teak. With some good advice from a friend who was a fine furniture maker / restorer in a past life I am hopeful of a good result. Will post some after picks once finished (hopefully in time for the upcoming summer!!!)
Name:  boarding p_form - bottom - before.jpg
Name:  boarding p_form - top - before.jpg
Old 10-28-2010, 02:30 AM
Finished! A blast with a hot water pressure cleaner and 3 coats of Wattyl Estapol 7008. Pretty happy with the result for what adds up to about 5 hours of work.
Old 11-10-2010, 07:18 PM
And on the boat. Has certainly provided the inspiration to continue the work and bring the rest of the boat to the same standard... but that is for next winter, Summer is here. So for now, a quick going over of the engine (change fluids, filters, water pump etc), have the prop balanced, install a perfect pass and boom bar and it's ready to enjoy!!
I'm interested in finding out the history of the boat which has still has the US rego ID on it and a couple of stickers that might help ID it, so will post these in an appropriate thread and see if anyone out there knows the boat.
Old 12-02-2010, 05:16 PM
mallees's Avatar
mallees mallees is offline
Boat: MasterCraft X2 2004 350 MCX
Hi Prostar190Downunder, Although your teak looks great at the moment, I would be a bit worried that it will crack and peel after exposure to water. I am not in any way a paint expert, but I was told to steer away from any form of varnish on wood that will be submerged in water. Everyone on here normally uses teak oil. There is a article here somewhere by TMC01 that explains really well, the best way to look after your teak, (I just can't find it at the moment)
