Old 05-28-2015, 09:59 PM
mtajpa's Avatar
mtajpa mtajpa is offline
It seems he went through the complete transmission to find that it was his dampner plate. If your noise goes away just above idle when in gear I wouldn't worry to much about it. It seems like everyone with the ZF hurth 63 has the same complaint in fact there is a bulletin out about this exact issue. The bulletin says to use the 10w40 engine oil to quite the noise. I still transfluid in mine. I do run mine hard skiing at 34mph, surfing, and getting to my favorite spot which is usually 45 minutes by boat at 30plus mph.
I'm not saying there is a problem or not if your are uncomfortable with the noise its your call how far to go investigating. I will be looking into a new dampner plate net year just because I will be over the 700 hour mark. Thats just my plan. I know how it sounds and always listening for something different.
Good luck
mtajpa
99 MariStar 230 Sport LTR 330
Old 05-28-2015, 10:12 PM
wetwillyskate's Avatar
wetwillyskate wetwillyskate is offline
Boat: Mastercraft Maristar 200 VRS
I read that pdf and had high hopes for swapping the fluid, which didn't make a difference.
I have the "HSW 450 D" trans. Any idea how this differs from the 630?
Old 05-28-2015, 10:27 PM
mtajpa's Avatar
I am not sure what the difference is between the two. I have the 230 Maristar larger boat larger trans maybe. Somewhere on here is a model guide with the ratings.
Old 05-30-2015, 02:57 PM
Found the rock in my trans...Name:  ImageUploadedByTapatalk1433011953.097658.jpg
The fly wheel itself was loose. Likely after the one bolt failed. Maybe they were all never fully torqued.
I'm going to replace the dampener plate too because it's a rust bucket and all of the springs are loose.
Hopefully this is my smoking gun.
Old 05-30-2015, 04:43 PM
milehigh970's Avatar
milehigh970 milehigh970 is offline
Boat: 1986 skier w/ a fresh 351 and 2008 x2 w/ MCX
Nice catch!! That could of turned real bad!!
Old 05-30-2015, 08:47 PM
mtajpa's Avatar
Your "ROCKS" must have been louder than mine. Ditto on the find. You will sleep better I'm sure.
Old 06-29-2015, 06:05 PM
toocoolgun's Avatar
toocoolgun toocoolgun is offline
Boat: MasterCraft, ProStar 190, 1991, 351
Just pulled my tranny because of noise. everything feels fine when rotating by hand. Hopefully it just the damper plate. Does anyone know what I need to torque the damper plate bolts to?
Thanks in advance for replies.
Troy
Old 07-08-2015, 10:41 AM
IIRC these were 7/16 bolts and i used blue loctite and torqued to 52 ft-lbs with new grade 8 bolts according to a general torque spec i use at work for 75% preload. also: https://www.boltdepot.com/fastener-i...ed-Torque.aspx
The flywheel bolts were spec'd to 74 lb ft and i used ARP bolts there with ARP assembly lube. NO chance this is happening again to me again.
drivetrain, engine noise, indmar, maristar, rattle
