Old 10-18-2018, 09:59 PM
waterbuffalo's Avatar
waterbuffalo waterbuffalo is offline
Boat: 1997 basstracker, 2000 Targa 210, 2007 mastercraft CSX..
Can you take that piece off and show me the crack or where itís broke.
Old 10-19-2018, 11:56 AM
crashmore22's Avatar
crashmore22 crashmore22 is offline
Boat: Mastercraft X-Star 2006
This is where mine broke on both sides. OP did yours break in the same area? FYI the black stuff is anit-seize that I put on the leg after I tig welded it.
Old 10-19-2018, 01:27 PM
So, what does that pin do thatís on the broke part? Is it just a alignment pin? Or does it pull the tower together??
Old 10-19-2018, 02:45 PM
I honestly don't know. I was shocked when I pulled the tower apart and found the pin. The piece appears to be machined from a single piece of billet. When I asked Gere Marie the difference in the Generation 1 (broken piece) and the Generation 3, they said the radius was changed. I put it in my vertical mill at home and measured it with a dial indicator and they were the same...
Old 10-19-2018, 03:25 PM
lakedrum03's Avatar
lakedrum03 lakedrum03 is offline
Boat: 2003 X-Series MCX
Looks to be some sort of alignment dowel.
That is an odd piece. Why have all of that stress on 2 little ears?
Being on a boat that's moving through the water, it's so clear. Everything falls into place in terms of what's important and what's not. - James Taylor
Old 10-19-2018, 10:06 PM
2007 x-star broken tower.
That dowel pin looks like a design change, to give it more shear strength, maybe. They should have put a better piece of alum in there.
