  #41
Old 01-23-2013, 12:39 PM
jeff shelton's Avatar
jeff shelton jeff shelton is offline
Boat: 1990 prostar 190 with 454 and slot
Go-to is a 13x13 LH for the 454 regardless of the gearing ratio. There are other possibilities. Keep it simple and functional. Don't worry about making Jeff Foxworthy proud.
As was stated, if you want to know the current 4 banger, pull the prop and look on the hub.
My 1990 190 with powerslot trans has a ACME 4blade 14x20. Top Speed right at 50mph. I'm not sure what would have been installed from the factory.
I do have an additional 3 blade that came with the boat but I'm not sure of the size. The dealer that I boat the boat from said that they installed the new 4 blade because the boat was turning 5600rpms with the 3 blade. I have yet to run the prop to confirm rpms and speed.
Old 01-23-2013, 01:43 PM
TRBenj TRBenj is offline
Boat: 1990 Ski Nautique
Those numbers make sense. The 13x14 Acmes work well on the 1:1 big blocks. Multiply that 14" of pitch by your 1.5 reduction and youre at 21"... so 20" isnt too far off. How many RPM's do you pull that prop? My guess is 4600 +/-? 50mph seems about right for a 330hp BBC in a 19' ski boat. Thats where most of the 454 Barefoot Nautiques and Ski Nautiques run.
5600rpm would imply that the other prop was a pretty gross mismatch for your powertrain. Probably in the 13x14 to 13x16 range? Either that or the 5600rpm claim is likely incorrect.
Old 01-23-2013, 03:33 PM
I didn't not mention previously but it does have the 454 with slot. You are correct on rpms. They are right at 4600rpms.
I had planned to put the other prop on before the end of this past summer to see what the rpms and speed were but just didn't get to it. I do think it is a 19 or 20.
Old 01-23-2013, 05:22 PM
Probably a hand finished prop (Federal maybe)? If so, then add 200 or so RPM for the different style if the same pitch... if less pitch, add another 150-200rpm per inch. If its a 19" and turns more than 5k RPM then its probably flexy (ie, worn out). Ive seen that a few times.
Old 04-13-2013, 09:11 PM
kbrighton's Avatar
kbrighton kbrighton is offline
Boat: 91 Prostar 190 - 454HO
Its ALIVE!!!
http://youtu.be/WXp7SFLOzqE
Old 04-14-2013, 10:35 AM
onejdgreen's Avatar
onejdgreen onejdgreen is offline
Boat: 02 ProStar 197TT "Caddy H2O" & 1980 MC Stars & Stripes, "Boss Hoss"
Great purchase!!! Gotta love the rumble of a big V8!!!
Old 04-14-2013, 11:06 AM
Originally Posted by kbrighton View Post
Now if we could get some weather...
Old 04-14-2013, 11:08 AM
kbrighton's Avatar
I might go out this afternoon as long as the rain stays east and north of us. I can work with a high of 69 today
Old 04-14-2013, 11:09 AM
we're going to have 20+mph winds
Old 04-14-2013, 08:52 PM
kbrighton's Avatar
So it ended up getting to 74 today, but windy too. As you can see though, the river tends to be calm regardless of wind conditions.
